Tire rotation pattern
Discussion in 'Clarity' started by bigbug, May 17, 2019.
  1. bigbug
    bigbug Member
    On page 506 of the owner's manual, 2 different rotation patterns are shown for "tire without rotation marks" and "tire with rotation marks". I don't know what a "rotation mark" is, and can't find a mark on the OEM tire. Which pattern should I follow?
  2. Clarity_Newbie
    Clarity_Newbie Active Member
    bigbug
    A tire with an "arrow" on the sidewall indicates that it is unidirectional. The arrow denotes the tire is to be mounted as facing forward and some are noted as "left or right". Tires should only be rotated front to back unless other steps are taken.
    Tires without the arrow are more traditional and are rotated in the "x" pattern as it were. The OEM LRR tires that came on the Clarity are non-directional.
    Link to short explanation https://www.lesschwab.com/article/what-are-directional-tires.html
    Hope this helps
  3. KentuckyKen
    The OEM LRR Michelin’s are non-directional tires and thus can be swapped from side to side. Believe it or not there is an actual Tire and Rim Association which publishes tire rotation recommendations. Here is their info and some Clarity tire and wheel info I gleaned from my always helpful fellow Clarity forum posters.
    Tire size 235/45R18 94V
    OEM is Michelin AS Energy Saver
    55,000 mile warranty, non directional
    Wheel size 18 x 8J ET 50
    Bolt Pattern PCD 5x114.3
    36 psi
    19 mm lug nuts
    80 ft/lbs torque
    The Tire and Rim Association recommends the Forward Cross for FWD nondirectional Tires and rims
    Tire repair info from Tire Rack posted 3/1/19 by @Sandroad:
    https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=77
    bigbug and Spring_Clarity like this.
  4. David in TN
    David in TN Well-Known Member
    I feel extra special. My tires rotate when I drive my Clarity.
    Spring_Clarity and tom kirshbaum like this.
  5. bigbug
    bigbug Member
    Thanks for the info. I just had the tires rotated at a local shop where they only swap front and rear. Will swap side to side as well next time.
