Sound deadening plugs
Discussion in 'Clarity' started by Tim Wingler, Aug 1, 2019.
  1. Tim Wingler
    Tim Wingler New Member
    Where are the sound deadening plugs located?
  2. KentuckyKen
    What he said.
    Attached is the Clarity specific PDI that has that info and a whole lot more, including jack points and the need to lower tire pressure down from the high shipping pressure. Dealers often forget to do that.
    ClarityDoc likes this.
  3. Mowcowbell
    Mowcowbell Well-Known Member
    The real question: do they work? My own ear tells me there is no difference before and after the plugs.
  4. blastfurnace
    blastfurnace Member
    I can't tell any difference at all for sound. I have no idea if they might help with water intrusion or whatever.
  5. MrFixit
    MrFixit Well-Known Member
    Couldn't really tell any difference in sound either but...
    We have had multiple instances of rodents getting inside vehicles parked outside, chewing through wires, storing acorns, building nests, etc.
    Blocking possible entry points seems like a wise idea. Also makes sense for water intrusion as mentioned.
  6. Mowcowbell
    I guess the name 'sound deadening plugs' is why I'm questioning any actual reduction in cabin noise. If they were called 'body water seals', I probably wouldn't have commented.
  7. Tim Wingler
    Thank you for the PDI. I was looking in the wheel wells.
  8. na zdrowie
    na zdrowie New Member
    We got them installed and found that it made a significant difference with road noise.
    4sallypat likes this.
  9. graure
    graure Member
    I bought them myself after 6 months because the dealership didn't install them on delivery. I notice zero difference.
    Mowcowbell likes this.
  10. Kerbe
    Kerbe Well-Known Member
    I drove the car on a set route this evening and then returned home to install the plugs. Then I drove the route again. I think, at highway speeds, I noticed a difference: Where there had been a kind of flutey whistling sound on smooth pavement, it was no more. There is, however, so much road noise that it's difficult to determine what one is or is not hearing. An annoying rattle on rough pavement turned out to be my sunglasses in the hard plastic ceiling holder: I guess I'll either have to line it with foam or put my glasses in a case before storing them there.
  11. Mowcowbell
    I had the same issue with a rattle that drove me nuts until I removed the sunglasses in the ceiling holder!
    Johnhaydev likes this.
