Reduce charge rate
Discussion in 'Clarity' started by Timothy, Aug 1, 2018.
  1. Timothy
    Timothy Active Member
    Isn't there a option through the central console to reduce the charging rate? Or am I just remembering one of the many other plug-ins we test drove? I searched both the manual and the guide (I still don't understand the distinction) for the term 'charge' and found nothing about this. If there is such a setting could someone help direct me to which menu it is under. Thanks.
  2. jdonalds
    We can set the charge rate through the JuiceBox charge station. I don't believe the car has that option.
  3. MarkClarity
    MarkClarity Active Member
    The charge rate is controlled by the EVSE cable which sends a 12v signal on the pilot wire to tell the car charger how much current to draw. Sample values from the J1772 Wiki:
    The signal can actually specify any amperage between 0 and 90A
    There are no known settings in the car to override this.
  4. Odobo
    Odobo Active Member
    It's available on the other cars you test drove... Not on the clarity.
    Timothy likes this.
  5. Timothy
    Sadly, I have come to the same conclusion. And yet I have no regrets. Maybe it was the Volt, the Bolt, both? We are happy with the Clarity.
