Got the original seat covers for Clarity. The part that goes on the seat itself keeps sliding away. It supposed to keep in place by several “tabs” that are tucked under the seat, but they keep getting out no matter how good I puts them in. Am I alone with that issue? I am thinking to remove the seat and use rubber bands under it to hold the cover. (btw what is the procedure for seat removal?)
Problem solved I removed horizontal part of the seat (instruction here ) Stitched some rubber string from underware to the tabs Later got a better idea and drilled tabs and used plastic tie wraps to connect them to metal bars inside the seat Also had an issue with the small side vertical cover - lower tab always crawling out. Put a tennis ball under that part to hold the tab in place. Seems to be good now, and looks way better
Great video instruction on removing the rear seats! This level of videography and clear instructions sets the bar high for the rest of us. Thanks for one more tool in our tool kit. And on how to then keep the rear seat cover nice and tight. Hats off to you, sir!
