Obd scanner port : where is it?
Discussion in 'Cooper SE' started by Luis Abreu, Sep 4, 2021.
Tags:
  1. Luis Abreu
    Luis Abreu Member
    Hello guys.
    Anyone knows where's the obd scanner port on the se?
    Thanks.
  2. MichaelC
    MichaelC Well-Known Member
    While the title of this video says "2014-2020", this is the location for all F56 cars (left-hand drive).
  3. Luis Abreu
    Luis Abreu Member
    Thanks Michael... Bad location... And it seems like you need to completely remove the bottom protection...
  4. MichaelC
    Since this port is intended for diagnostic use only, ease of access for the owner probably wasn't a design consideration.
    On my 2021, there aren't any panels/protection to be removed. Everything is already exposed as shown in that video.
    Texas22Step likes this.
  5. Luis Abreu
    Luis Abreu Member
    Mine is also from 2021... I'll have another look, but I'm almost sure that there's some sort protection there...
  6. insightman
    No cover on my 2021 Iconic. I'm glad the OBD port is against the left side where it's easy to access while kneeling on the ground. Some manufacturers force you to lay on the floor on your back to find the port near the center.
  7. quietlyspinach
    quietlyspinach Active Member
    Yup, no cover on my 2022 Iconic. It's just exposed facing downward right above the left foot rest. You can easily feel it with your fingers.
  8. Luis Abreu
    Luis Abreu Member
    You're right guys. No cover, it's just there... Not sure on how I missed it before...
    Thanks again.
  9. ColdCase
    ColdCase Active Member
    I seem to always need help finding the ODB port on any new car, sometimes they blend in so well.
    BTW, not that its relevant for an electric car, in many US counties the ODB port is used for annual emission performance verification in addition to its diagnostic use.
    Novadar likes this.
  10. Can't believe they've made it so difficult to get to. In the UK F56 (including the SE), you don't even have to exit the car. Its just behind a small cover that flips out, just about the hood release.
