No device connected
Discussion in 'Clarity' started by Mikesmith78, Aug 17, 2019.
  1. Mikesmith78
    Mikesmith78 New Member
    I use android auto with clarity and it works great. But when I don't plug my phone I get a black screen that says no device connected when I start the car. I have to press home to get to the main screen. Is there way to remove the black screen from coming. I wish it would default to the home screen all the time. Is there a setting for this
  2. coutinpe
    coutinpe Active Member
    I think when you turn on you get the same screen you had when you turned off. Have you tried to switch to home screen before switching off the car?
  3. Paddy
    Paddy Member
    I like this feature. I can get right back at where I left off if I stopped for some errands
    MPower likes this.
  4. Mikesmith78
    yes, it doesnt matter which screen i last had it. the next time i start my car it shows the no device connected screen
  5. fotomoto
    fotomoto Active Member
    Hmmm.
    Could it be the USB cable that I assume is still plugged into the USB port that is causing the notification?
  6. Mikesmith78
    Yes, the USB cable is still plugged in. That would be annoying if I have to remove the cable for that to go away
  7. Mowcowbell
    Mowcowbell Well-Known Member
    I've noticed this 'feature' when using AA. I guess I'd rather it try to open that source on the next restart versus automatically switching to a source that I no longer have like sat radio.
