NEMA 14-50 meltdown
Discussion in 'General' started by bwilson4web, Aug 3, 2021.
  1. bwilson4web
    Parts, yes, but the root cause is probably the wire connector. Some will naturally 'back off' enough to become a resistance capable of generating a lot of heat. The soft metal of the wire gradually relaxes its shape leading to heat.
    The easy fix is to retorque the wires after a year or two.
  2. Typically, I terminate the wire twice.
    The first time crushes the strands into the shape of the connector, then I wiggle the wire to loosen it up and then apply the factory spec'd torque a final time to establish a solid proper connection.
    This can be difficult to do using a straight blade, which is another reason I like the new Leviton EV charging receptacle mentioned earlier post, as it uses Allen (hex key):
    Nothing wrong with checking and re-torquing at a later date just to be sure.
    Harvey, insightman and bwilson4web like this.
