Model Y dimensions and weight
Discussion in 'Model Y' started by Domenick, Mar 9, 2020.
  1. The physical dimensions for the Tesla Model Y are now out, along with weights.
    • Exterior Dimensions:
    • Overall Length: 187 in or 4,750 mm
    • Total Width:
    • * Overall Width including mirrors: 83.8 in or 2,129 mm
    • * Overall Width including folded mirrors: 77.9 in or 1,978 mm
    • * Overall Width excluding mirrors: 75.6 in or 1,921 mm
    • Total Height:
    • Overall Height: 64 in or 1,624 mm
    • Curb Weight* Long Range Battery, Dual Motor: 4,416 lbs or 2,003 kg
    • GVWR** Long Range Battery, Dual Motor: 5,302 lbs or 2,405 kg
    • Gross Vehicle Weight Distribution - Dual Motor: Front 46% and Rear 54%
    • Gross Axle Weight Rating - Front 20" Wheels: 3,005 lbs or 1,363 kg
    • Gross Axle Weight Rating - Rear 20" Wheels: 3,307 lbs or 1500 kg
    • *Curb Weight = weight of the vehicle with correct fluid levels, no occupants and no cargo
    • **GVWR = Gross Vehicle Weight Rating
  2. Wonder what the ground clearance is?
  3. Azjohnny
    Azjohnny New Member
    its about 6.5"
