looking for organizer for level 1 charger supplied
Discussion in 'Clarity' started by JKroll, Sep 24, 2018.
  1. JKroll
    JKroll Member
    Any experience with putting a organizer/Holster Dock for level 1 charger in garage.
    Any photos and where to buy the components will be appreciated.
  2. Heino
    Heino Active Member
    amy2421, KentuckyKen and V8Power like this.
  3. David A
    David A Guest
  4. David A
    David A Guest
    JKroll....took a pic this morning after the cable was put up for the day as an FYI.
    The worlds your oyster.
    Good Luck!
  5. qtpie
    qtpie Active Member
    David A likes this.
  6. amy2421
    amy2421 Active Member
    I like this a lot. I have a ChargePoint charger in my garage, which has this built-in, but in nicer weather it would be great to have an outdoor holster and hanger to use outside of the garage.
    David A and Heino like this.
  7. Carro con enchufe
    I use the same exact hook. It’s screwed in about 2 feet above the outlet, for quick storage.
    David A likes this.
  8. Breezy
    Breezy Member
    Has anyone tried this slanted holster for Level 1 charge connector? I want the most protection since it will be outdoors. Even if listed as level 2 it should work, no? Wondering if the small cover our level 1 comes with (attached by plastic tether when connector in use) will fit in here.
    AmazingE EV Charging Station SAE-J1772 Wall-Mount Connector Holster
    https://www.amazon.com/AmazingE-Charging-SAE-J1772-Wall-Mount-Connector/dp/B072MP3N1Y
