ICE Breaker
Discussion in 'Clarity' started by bobcubsfan, Jun 4, 2018.
  1. bobcubsfan
    bobcubsfan Active Member
    How does one charge the 12v battery?
  3. insightman
    I don't believe there's an alternator in any of Honda's hybrids. A DC-to-DC converter steps the big battery's voltage down to recharge the 12-volt battery. Still, checking the 12-volt battery wouldn't be a bad idea.
    The Clarity's battery is certainly more accessible than that of the 2019 Insight! Where do I drill the holes in the console to attach my jumper cables?
  4. bobcubsfan
    Okay, how do I check the battery? I don't have an industrial volt meter.
  5. bobcubsfan
    A Honda rep told me that they pay no attention to Forums or other 3rd party sources.
  6. LegoZ
    LegoZ Active Member
    They want to be the sole source of misinformation :D
    bobcubsfan and K8QM like this.
  8. bobcubsfan
    Worked for Hitler.
  9. KentuckyKen
    Yep, no alternator but if his battery is not holding a charge, I could see the ICE running the starter-generator to charge the 12v battery (if indeed that’s how it charges it). Or does it charge from the HV battery? I can’t find that written down anywhere. For efficiency’s sake you would hope it’s off The HV battery by a DC to DC converter. Anybody know for sure?
    One good diagnostic test would be to go to an automotive store and let them test the 12v battery to see if it’s good or.
  10. insightman
    In all Honda hybrids, a DC-to-DC converter steps the big battery's voltage down to recharge the 12-volt battery.
  11. KentuckyKen
    In that case, a bad 12v would not explain Bob’s excessive ICE operation.
  13. bobcubsfan
    I agree. Drove again this morning with a full charge. Hit brakes hard and regen paddles. ICE did not come on.
  14. brady
    brady Member
    Geo, if this is the case it might explain why the ice must kick on randomly...I know for a fact the main battery is NOT used to charge the 12v engine battery. Therefore if it loses charge the ice MUST kick in to charge the 12v when it get below a certain point. If your battery is weak and hovering on the low side it will kick in more frequently.
  15. brady
    brady Member
    Bob did you charge the 12v battery after a successful drive without ICE kicking in?
  16. brady
    brady Member
    I was having issues with my Brand new 2015 Leaf, I took it back to the dealership several times. It had erratic and strange behavior. Frustrated and defeated, I called Nissan and somehow (after 2 hours) got in touch with a technician that helped designed the car...He told me that on electric cars the main 12v battery, if not charged, will cause many problems. I never forgot this and after I charged the 12V the Nissan acted perfectly for the remaining 3 years. So naturally when I brought the leaf home I charged the 12v. T
  17. KentuckyKen
    Bob, regardless of how the 12v battery gets charged, could you take your Clarity to an automotive parts store and have them give you the free battery test and let us know the results?
    This would be quicker than going to he dealer and would confrim or rule out this possible cause.
  18. bobcubsfan
    We had two Leafs. Both had a solar panel that charged the 12V. However, the main battery could be called on to charge it when necessary. That solar panel was deleted from the 2018 Leaf, so presumably the main battery is used to charge the 12v.
  19. bobcubsfan
    Will do. I guess Pep Boys would do that.
  20. brady
    brady Member
    The engineer for Nissan told me that the propulsion battery will never charge the 12v battery. However, I still think you could get an OK that the 12v battery is not bad (check out ok at pep boys) BUT it still could be low and causing issue. My suggestion is to CHARGE the main battery with a 12v car battery charger (trickle charger will work). I honestly think you are chasing your tail until you eliminate this possibility. If it doesnt work you have peace of mind and can tell me to *$%* off. jk. I found mine an Amazon for about $40, there are cheaper ones too.
  21. bobcubsfan
    This is from the 2018 Nissan Leaf manual
    CHARGING THE 12-VOLT BATTERY
    The 12-volt battery is charged automatically using electricity stored in the Li-ion battery.
  22. KentuckyKen
    I think the battery test will tell him if the battery is in a low SOC by the voltage. And if it’s very low, it won’t even be testable. The load test will also shed light on its strength or capacity.
  23. bobcubsfan
    I will report back later today after battery test.
