I Phone
Discussion in 'Clarity' started by BobS, Dec 2, 2018.
Tags:
  1. BobS
    BobS Active Member
    If there are two I Phones paired to the Clarity, how does it work? Does it connect to the one it finds first?
    If connected to one phone is it possible to switch the connection to the other?
  2. Skynosaur
    Skynosaur Member
    If you go to settings. Click connections, Bluetooth. You can select which phone to use. Only one phone connects at a phone.
    Sent from my G8142 using Tapatalk
  3. amy2421
    amy2421 Active Member
    I think you can set which phone is the primary, so if both phones are in the car it will automatically connect to the primary phone. If only the secondary phone is present, then it will connect to that one.
  4. rodeknyt
    rodeknyt Active Member
    Sadly, this is not the case. Honda's Bluetooth system is so far behind everyone else it is laughable. You can't prioritize multiple phones that are paired to the system. It will only connect to the last phone it was connected to, if it is in the car, and may or may not automatically connect when only one phone is in the car if it wasn't the last one connected. If it doesn't, you have to manually connect through the phone settings screen.
    Thanks so much Honda.
