2800 miles.. 6/32 fronts, 8/32 backs. I might be having too much fun.. On the positive side, they are wearing evenly from inside to out.
I've got just shy of 12,000 miles on mine, about 60% of that on summer wheels and 40% winter. Just swapped my wheels so I have the stats. Winter tread: front 7mm, rear 8mm Summer tread: front 5.5mm, rear 6mm And for completeness, brakes: front 11mm, rear 9mm
I'm curious about how much wear those numbers represent. Do you know the thickness of the pads when new? Do you use the brake pedal often? I don't.
I consider it a failure if I touch my brake pedal, but the traction control uses the brakes whenever it decides to. Inspection technician said should be replaced at 3mm. I think they must be 12mm when new?
For sake of comparison mine would be: 4.76 mm front 6.35 mm rear Metric is better.. Anyone worse than me over 3k miles?
For me its between 8.5-9/32" all around @ ~6200 miles on Michelin Crossclimate2 (205/55R16 91V) tires and I drive it hard. It's 10/32" when new.
killing my stock fronts ATM. Waiting for the new wheels and I will have 225/18 tires on soon, so they will fare better! lol
Are you running the Ventus EVO 3? I can’t say I’ve been impressed with the tread life. I knew I was driving hard, but not that hard... 215s.. wow! Fat tire for a Mini. Please post pics after you get them.
I have the goodyear's. I wrote 225 and you wrote 215. You were right, 215/40-18. I have Kumho's coming.
