I have a 7 year old Tesla that I am looking to replace. I'm considering an EV6 Wind AWD. I understand the regenerative braking level can be set with the paddles on the steering wheel. Question is: do you have to set it each time you drive, or is it a set once type of option?
On the EV6, there are 4 setting. If you set at 1,2 or 3, it will hold that setting the next time you get in the car. If you like to use I pedal, the max setting, it will always reset to 3 the next time you get in the car, which means you need to reset to I pedal if that’s the way you like to drive.
