Energy use on highway
Discussion in 'Hyundai Kona Electric' started by Boston Charger, Aug 3, 2021.
  1. Boston Charger
    Boston Charger New Member
    Settle an argument...while driving on the highway, my son sets the level to 3 arguing that the bar shows neutral, not charging nor using energy. I set it to 0 when driving highway. Driving in 3 feels like driving in third gear of a 4 speed transmission where 0 feels like overdrive in conventional vehicles.
    Which setting uses less energy?
    TIA
  2. Tim94549
    Tim94549 Active Member
    How about testing it ... ?? Drive in CRUISE Control at 65 in both modes for like 10-20 miles - using the same direction/path each time. Then check your KW Usage ... Personally, I always run in ECO and level 3 ...
  3. ENirogus
    ENirogus Active Member
    In the Kia anyway, I think cruise overrides the settings, but I could be mistaken
    Lots of people have been saying that no regen on the highway is more efficient, but I have not seen a difference in my limited experimentation
  4. KonaTom
    KonaTom Well-Known Member
    I switch to 0 regen on highway too. It just seems like it should be more efficient rather than having the car switching between regen and drive many times as you drive. Don’t have any proof tho
  5. nigels
    nigels Active Member
    I don’t do much highway driving, but when I do I like to use active cruise control to follow the car in front, regenerating automatically as the followed car slows down. I suspect 0 regen would be most efficient if you have the leeway to allow the car to speed up down hills and use that kinetic energy to help the car up the next incline, and perhaps slow more than you would if you had cruise set. I learned that kinetic approach with my first car, an 850cc Mini that needed all the help it could get to go up hills!
    Around town, I use level 3 regen for one pedal driving. I’m getting 5.9 mi/kWh with that and don’t see a need to change since I’m never doing 80 to empty expeditions.
  6. It doesn't make any difference and why should it?
    The only difference is that you have to maintain foot pedal pressure with regen set to >0
    Otherwise you're coasting in both modes and thus doesn't make any difference in kWh used per mile.
    Just a question of user preference.
    John Lumsden likes this.
