Duosida Overheating?
Discussion in 'Honda' started by WyattJohn, Mar 3, 2020.
  1. WyattJohn
    WyattJohn New Member
    I finally got my 20 amp 240 outlet installed. I plugged in my duosida 16a lvl 2 charger and set it to begin charging at midnight and charging until full. When I awoke in the morning the clarity was fully charged but the indicator lights on the evse indicated overheat protection. Odd since it fully charged.
    Thoughts?
  2. craze1cars
    craze1cars Well-Known Member
    It actually got hot and/or is defective. Contact manufacturer.
  3. WyattJohn
    I think the newer chargers have a temperature sensor in the plug. Plug overheating is usually caused by a worn or defective outlet. It's cheap and easy to replace it - I would try that first.
  4. David in TN
    David in TN Well-Known Member
    I have ZenCar 16 amp charger, which has a Duosida Connector on the end.
    At home, with 20-amp service, I have had the same thing happen; however, when using it with either my 120-volt adapter or my RV-adapter, I have NEVER had an issue. Using the stock Honda adapter on the same 240-volt, never an issue with it charging either.
