Driver Display Compass: unconventional display of East and West
Discussion in 'Clarity' started by rlentz4367, Nov 5, 2018.
  1. rlentz4367
    rlentz4367 New Member
    Have others noticed that the compass in the Driver Display shows W to the right and E to the left in the circle display? N and S are at the top and bottom, nothing unusual there; but all the maps I've ever read show W on the left side, E on the right side. (The direction of travel, in the center, always reads correctly; it is just the notations for rotation of the arrow at the edge of the compass that seem, well, weird.)
    If there is an update or a way to change preferences, I would welcome knowing about it.
    Otherwise, I love the Clarity!
    Thanks.
  3. ExpensiveToys
    ExpensiveToys New Member
    Looks like they are using a quadrant notation compass instead of a azimuthal compass. Quandrant setup is usually used on professional Brunton and higher end compasses. I am not sure if there is a way to change it, as its more than just swapping the letters they would also have to change how the model behaves which might not be in the programming.
  4. petteyg359
    petteyg359 Well-Known Member
    OP says west is at 90°. That should never be the case, regardless of how you're measuring.
  5. rlentz4367
    Agreed. I have a friend who is an astronomer who explained the Quadrant Notation possibility.
  6. ExpensiveToys
    West at 90 and East at 270 (which really isn't 270 in a quadrant compas) is normal on a compass rose and common in higher end quadrant compass. On those compasses the east and west are reversed on the compass rose from what you expect due to how they are read. It's common in survey equipment, nautical compasses and other scientific compasses.
    http://earthsci.org/education/fieldsk/compass/compass.html
    https://www.stanleylondon.com/profaq7.htm
    A direct reading compass (most often Quadrant compasses) have the East to left of North and West to right of North on the to make them easier to read. See the above links for complete explanations.
