Do the EV tail lights fit the PHEV?
Discussion in 'Clarity' started by Tek_Freek, Nov 20, 2019.
  1. Asking for a poster in the FB group. And curious myself.
  3. insightman
    Because it's such a low-volume car, I assume Honda didn't want to manufacture a different set of rear fenders for each model of Clarity to go with model-specific taillight lenses. That's as close as I'll get to guaranteeing all Clarity-model taillight lenses are interchangeable.
  4. GHTech
    GHTech Member
    Interesting. Didn't know that there was a difference.
    CyberDyneSystems and KentuckyKen like this.
  6. graure
    graure Member
    This is one of those ideas where you're pretty sure the answer is going to be yes, and then you take it apart and find out that the other lights have completely different connectors. This was the case with the regular gasoline Civic and the Civic hybrid (which also had clear tails).
  8. graure: Did you see the images I posted?
  9. graure
    graure Member
    While I'm sure that the light itself will bolt up just fine, the harness connector may be wired differently, which is exactly what Honda did with the Civics. A possible way to check without having the actual light would be to look up the part number of the BEV harness and see if it's the same as the PHEV one.
    JustAnotherPoorDriver likes this.
