Dashboard Squirrel Sound?
Discussion in 'Hyundai Kona Electric' started by Konan the Explorer, Mar 13, 2021.
  1. Genevamech
    Genevamech Active Member
    My first thought was a dodgy vent damper, which at motor operated to direct the air to windshield/forward/footwell. If there's a loose linkage or the motor is twitching for some reason then it could make a noise. The fan running is also entirely possible, but I don't think the fan is anywhere near where the noise is described.
    One way to check is to turn the fan on at various speeds and see if that affects anything. Might be hard to tell if the issue is intermittent though. You can also get a cheap borescope and peek through the vents in the console to investigate, assuming you think the noise is coming from the ductwork.
    navguy12 likes this.
  3. Loc Quan
    Loc Quan New Member
    Does the car have a heads up display? There is a motor that opens/closes the hatch and moves the display up/down.
  4. Video tape it with your phone if possible.
  5. I read it illuminates because it’s letting u know that the motor battery is charging your battery under the hood.
  6. Guy Tower
    Guy Tower New Member
    I once had this noise in my Subaru, only to find out that a dead dried up tree leave somehow inserted itself close to the ventilation system, and was rattling on and off, depending on the wing, car ventilation, etc.. I found the leave partially inserted behind the dashboard's vent
    BC-Doc, navguy12 and Wildeyed like this.
  8. Suggestion:
    Next time you hear it, set the infotainment system to display your power usage and check if Battery Care is active. If so, it could still be the HVAC system.
  9. Shade2
    Shade2 New Member
    I hear a similar sound on my 2018 Honda Clarity PHEV from time to time. When I first got it, not knowing what the sound was nearly drove me crazy, but now I hardly notice it. I'm pretty sure it's the car's telematics unit, sending data small chunk by small chunk. Hope this helps!
  10. Just an update, I had a dealer appointment for FOUR of the recalls and let the service manager hear the noise. He concurs that it is possibly some sort of vacuum actuator but it wouldn't repeat after that so no solution. He said he had never heard that before. A new clue is that now that the weather is warmer it has not done it as much? Hmmm....
    If I ever find it I'll give you the answer here
    BC-Doc and navguy12 like this.
  11. MSimpsonNJ
    MSimpsonNJ Active Member
    Konan the Explorer and navguy12 like this.
  13. beacon_outbound
    beacon_outbound New Member
    Hi. Did you ever get this issue resolved? Does it sound anything like this recording I made?
  14. No, that sounds more like the fan is out of balance or has a bad bearing this was much more intermittent. Then it went away and has not returned this winter, last winter it was more frequent.
