Could be interchange battery pack from 24Kwh to 40Kwh
Discussion in 'LEAF' started by Marc Vendrell, Dec 11, 2018.
  1. Hello
    We have a Nissan e_NV 200 24Kwh, if I change all the battery pack from a Nissan Leaf 50kwh, this van will have more capacity to make more km. But I think so that then, I’ve to reprogram the inverter, because have to know it that we change their capacity from 24kwh to 50kwh.
    Do you know any company that is doing this job?
    Do youknow any equipment to check the SOH, SOC, and battery capacity?
    Thank you in advance.
  2. Kenneth Bokor
    Kenneth Bokor Active Member
    Hi, you can use the Leaf Spy Pro IOS/Android App to get accurate SOH and other stats, along with a supported OBD2 BlueTooth adapter. Check out the Leaf Spy Pro app in your mobile store for more info and supported adapters.
  3. Thank you so much Kenneth for your reply. I've get some news I'll let you to know it.
    best regards.
