Clock time change
Discussion in 'Hyundai Kona Electric' started by R P, Nov 4, 2019.
Tags:
  1. I noticed yesterday that the time did not switch back to standard time. I thought maybe it needed some time to connect with my phone or sat system to correct, but didn't happen. So today I went into my clock settings and saw that DST was checked. I unchecked it and my clock then changed and displayed correctly.
    So, does that mean that DST time changes are not automatic in this car? And you need to check or uncheck DST with every time change?
    ehatch and Francois like this.
  2. ericy
    ericy Well-Known Member
    I had to do the same. My guess is that is not automatic as some states don't do DST.
    Sent from my SM-G930V using Inside EVs mobile app
  3. Hopefully the last time we will have to do this.
    ehatch likes this.
  4. Add that to the list of reasons to do away with DST ;-)
  5. Francois
    Francois Active Member
    Same experience for me. I removed the dst setting manually which felt a little odd to perform in an age where most things update automatically but in the end, it is not a big deal. :)
  6. davidtm
    davidtm Active Member
    Same for me in the Niro EV.
    Hate how long it takes our dogs to catch on to the time change . . .
  7. ericy
    I suppose in theory they could pick up the time e changes from BlueLink. I wouldn't want to depend on that functioning however.
    If you didn't have BlueLink, I don't know how you would pick up the time change reliably. Some states do dst, others don't. And even then, the rules change every once in a while.
  8. Gjpzee
    Gjpzee Member
    Mine changed automatically today. Not sure how though. I forgot to manually change it the last two days and then today I realized it changed itself.
  9. Gjpzee
    Gjpzee Member
    Never mind, it did not change itself. When android auto is connected, it shows the time from the phone. That got me confused.
  10. Francois
    I made the same mistake initially so you are not alone. Android automatically adjust the time as one would expect from most services createe in at least the past 10 years. Not hyundai apparently. :)
