Climate control or A/C control
Discussion in 'Clarity' started by Tim66, Jan 23, 2019.
  1. Tim66
    Tim66 Active Member
    I took my Clarity in for what I thought was a fix for an "Abnormal Water Temperature Reading." The service recall stated "Replace the climate control unit" But later down the page it says "Correction: Replace the A/C control unit. Are they the same thing?
    Tim
  2. Sandroad
    Sandroad Well-Known Member
    The 18-089 update required a part, a CPU assembly 06999 that is part number 06796-TRW-A00. Is that part number listed on your repair order?
  3. Tim66
    Tim66 Active Member
    -QUOTE="Sandroad, post: 46111, member: 5847"]The 18-089 update required a part, a CPU assembly 06999 that is part number 06796-TRW-A00. Is that part number listed on your repair order?[/QUOTE]
    That part number is listed in the first part of the order. But which update is it for, the Climate control unit or the A/C control unit or are they the same thing? The reason I'm confused is that the order says "correction" and then lists A/C control unit. It is probably just semantics but I'm curious. Thanks.
    Tim
  4. Sandroad
    Tim[/QUOTE]
    If that’s the part number listed on your repair order, those two descriptions are the same thing and it’s just dealer semantics. Both must refer to the 18-089 update.
    Tim66 likes this.
