Hey Clarity family How do I change and organize my Infotainment system to have 1) cool pics wallpaper 2) big icons like below
You need to go to the settings menu and under 'system' look for an entry called 'change skin'. Once you change the skin, you can upload pictures from you USB as wallpaper or use the native ones, which are quite cool too. Downside is the system can get a bit slower.
For some reason, the USB does not show any jpg. It's format in exfat. I plug it in both port. I can't seem where to find to import file. I follow instructions but won't show ADD file
Did you try FAT32? Microsoft released exFAT just a few years before Honda began designing the Clarity--the company may not have embraced that format yet.
You can do so through the regular frontend method, but the annoying part is that it won't persist. If you have root, then there is a way to save the change to the System partition. In the frontend settings somewhere, there should be a setting that changes between the legacy (i.e., the one depicted) and the current home UI style.
