Clarity BEV range
Discussion in 'Clarity' started by Tony, Jan 5, 2018.
  1. Tony
    Tony New Member
    What’s the farthest you’ve traveled on a full charge?
  2. Ken7
    Ken7 Active Member
    You probably also need to ask the temperatures at which their record occurred.
  3. JyChevyVolt
    JyChevyVolt Active Member
    I do 80 miles commute. I think you can do 100 miles staying under 65 mph.
    AlanSqB and Tony like this.
  4. Tony
    Tony New Member
    I made a 80 mile trip and was afraid I'd have to charge along the way.
    I not only made the 80 miles without charging but I had about 40 miles left on arrival.
  5. JyChevyVolt
    Dude, your a "Eco Ninja."
  6. Tony
    Tony New Member
    I'm not sure about the ECO Ninja, but thanks!
    Most of the time was spent fighting Los Angeles traffic.
    Averaging about 4.4 miles per Kilowatt.
  7. JyChevyVolt
    SOC 19%
    eschase, Domenick and Tony like this.
  8. Reno_bk
    Reno_bk New Member
    The range you are getting (and avg miles/kw hour) is pretty incredible. I've had my Clarity since Thanksgiving and have put about 800 miles on it so far. I've yet to take it on a long drive (beyond 50 miles), but I would be surprised if I could get 100 miles out of a charge.
    I've made a point of driving it pretty conservatively, using the regen whenever possible, using the climate preconditioner in the morning to heat the car while it's plugged in, keeping Eco mode engaged...about as efficient as I could possibly be, and still only averaging 3.3 miles/KW. That said, I leave the climate control set to 67-68 on Auto most of the time, as turning it off altogether lets the windows fog up pretty quickly. The mornings have been cold (30s and 40s), so I know the heater use has a big impact on range.
    I'm curious, to get 80-100 miles out of a charge, I assume you are leaving the climate control off? My range indicator usually shows a 15-25 mile reduction when I switch the climate control on, although that penalty usually lessens as the temps rise in the afternoon (been in the 60s during the day).
    I'm encouraged by the numbers you both are seeing - and I'm sure my efficiency will increase as we move into spring. We absolutely love this car - short range and all - because it fits our needs for a commuter perfectly, but I would like to take it on a longer drive one of these days just to see if my max really is around 60 miles (as indicated) or if I can stretch it closer to 80 or 90 with the climate control on.
  9. Tony
    Tony New Member
    JyChevyVolt likes this.
  10. JyChevyVolt
    You can turn on the fan only. Fan only at speed 2 will reduce the range by 2 miles. I've driven it in 40-50 degree weather and had no reduction in range.
  11. JyChevyVolt
    You are one efficient driver.
    My wife's terrible 2.5 miles/kWh is killing my average. She has the AC on and seat heater on. Why would anyone do that?
    Pogue and Domenick like this.
  12. ericzlot
    ericzlot New Member
    Sounds like the range mostly exceeds the estimate. I'm a current fit EV driver and I'm considering the clarity electric. Any fit EV drivers with a range comparison? I lose 40% of my range in cold weather below 60 degrees with no heat being used at all. Wondering how the clarity fares in similar conditions.
  13. AlanSqB
    AlanSqB Active Member
    I am so envious of you folks that can get the BEV. I have the PHEV and I’m loving it but for the sweet deal they’re doing on the BEV I would absolutely pick up a lease on a second one. After the CO rebate, it would practically be free.
    Also, I love that blue!
  14. rsbev
    rsbev New Member
    I was interested to find out how my Clarity BEV would do on a long climb. I took it up a 3900 foot elevation gain (almost 3/4 mile elevation gain), over a distance of 18 miles, starting with a fully charged battery. At the top, my display showed I was getting 1.9 miles per kWh on the climb, and a little more than half of a full charge left (about 55%, I'm guessing). The Range indicator showed 33 miles of range left (maybe optimistic, if I had continued climbing). After descending back to the starting point, there was still more than half of the battery charge left, maybe a bit more than at the top, due to regeneration on the downhill. The Range indicator is very much influenced by your recent driving, so at the end of the downhill return trip, it estimated way more miles remaining (130) than at the top, apparently assuming I was going to continue downhill indefinitely.
