Best mode for long upgrades
Discussion in 'Clarity' started by neal adkins, Oct 17, 2019.
  1. neal adkins
    neal adkins Active Member
    I thought i would share something i stumbled into when doing a long climb of about 6% upgrade for about 15 miles. This would not nessacarily apply to short climbs. I had the thought at the beginning of the climb to use hv charge and sport mode (soc was 50%), Since fuel economy is not very good anyways when using ice to climb in a 4k lb car. The result was improved performance. It kept my desired speed of 65 mph with no angry bees. The battery never was depleted during the climb, though it was around 30% when i reached the top. I think this worked good because the battery rapidly depletes at high speeds when climbing. As standard hv mode tries to maintain soc and speed, ice revs higher and the battery depletes faster. I have done this experiment 3 times now and prefer hv charge/sport mode for this 15 long 6% climb. I felt this was worth sharing because some people have been rather uncomfortable with the cars performance in long climbs.
    hamr4267 likes this.
  2. fotomoto
    fotomoto Active Member
    Is this the "infamous" grapevine section of interstate I frequently hear about?
  3. stacey burke
    stacey burke Active Member
    If you are getting "angry bees" you do not have enough battery. If you know your trip is longer than your EV range, use HV from the beginning of the trip - first button you press after the start button. I live in Colorado and go over the passes often. Never have I had the engine rev high. If you drive in EV and then go to HV on a long climb you will not have the battery with enough charge.
  4. neal adkins
    I know what you mean. This climb is in the middle of a 200 mile trip. So i use some ev in town. just use hv charge/sport in the climb when battery is below 58%.
  5. neal adkins
    Its the laguna moutain between Elcentro California and San Diego. But i have also heard lots about the grape vine. That upgrade is about 6 miles.
    No. I also have heard lotz about the grape vine
  6. ClarityBill
    ClarityBill Active Member
    This comparison of HV mode to HV charge mode does not quite make sense to me: The implication is that HV charge mode runs with lower RPM's, even though it is trying to build charge.
    I agree that both modes will lose SOC, but I thought HV Charge mode would respond with higher RPM's. (Since it is trying to build charge, rather than just maintain.)
    Do you have actual RPM data (OBDII) to back this up, or is it your ear?
    HV mode does have the RPM jump, when it gives up on gear mode: This makes the RPM increase sound worse. My hill climb method is to reset HV, stay in gear mode, and keep the RPM's low.
  7. stacey burke
    I have never used HV charge! worst way to get the best mileage. I use HV sport anytime my trip will be longer than me EV range. I press HV as soon as I start the car and keep the battery at the highest charge I can for mountains, merging, passing.
  8. neal adkins
    I think what it comes down to is that standard hv doesn't charge battery fast enough and it gets depleted before i reach fhe top. That is when it gets interesting. Slugish performance with even higher revving. So you are correct that both ways will rev. But once battery is depleted in hv mode you lose alot of power. But hv charge in sport mode doesn't allow the battery to deplete before i reach the top. So the ice and traction motor work in tandem all the way up.
    David Towle and hamr4267 like this.
  9. stacey burke
    Again, if you start your trip in HV the car will keep the battery charge level high and you will not need to use HV charge. Start HV when you start your trip...
  10. ClarityBill
    That makes sense. The goal is to have some battery remaining to the top of a long hill. Charge mode will bring in the RPM's earlier in the process. So the ice and traction motor work in tandem all the way up.
    neal adkins likes this.
  11. Could it have been the Jacumba Mountain Range? If so I posted something about my trip up those. The mountains start in Ocotillo CA and end in In-koPa.
  12. neal adkins
    Thats it! Nice Clarity by the way. Same color as mine.
  13. I live rather close to there, east of the mountains right off I8. Next time you pass through let me know. So I have to admit, I'm not a fan of driving my new clarity up that grade. The wife's SUV (traverse) doesn't miss a beat so we usually drive that when we go to San Diego. I never thought of using HV charge while climbing.
  14. neal adkins
    Even if you use regular hv with a full battery it still gets marginal fuel economy up that grade. So you use a little more gas in hv charge but have some ev range when you reach the top. Be sure to use sport mode/hv charge together for best performance.
  15. Clarity_Newbie
    Clarity_Newbie Active Member
    ClarityBill
    The link below is to some data taken whilst in HV charge mode. One data run not conclusive but it shows what it shows.
    https://insideevsforum.com/community/index.php?threads/clarity-issues.368/page-36#post-54842
    Hope this helps.
  16. neal adkins
    Many people think using ice is the devil. But the Clarity phev's longevity is better served using the ice in an intelligent way. Avoiding extreme battery draw for long periods of time(such as occurs during a long climb) will help protect your battery. Just like most don't waste the battery at highway speed, you can avoid excessive battery depletion by using charge stratigically. If i am driving 100 at 55 mph i could do about 55 miles ev then do hv charge for about 40 miles and use about 1.5 gallons of fuel and be back up to 30 miles ev range( thats how my car performs in my climate). That nets about 67mpg for that cycle. The next cycle would be 30 miles ev then 40 miles charge mode for 70 miles total at the same 1.5 gallons of fuel = about 46.6 mpg. Thats superior to the 40 mpg i get in strictly hv mode.
  17. stacey burke
    Why not start out in HV, save the battery for when you need it. At the end of the trip switch to EV and use it when you are within EV range of your destination? All posts and reading show that using HV charge is the LEAST effective way to use EV. Using EV charge means you have the engine running at a high rev to give power + charging the battery. In HV I have never had my car go into a high rev even when I drive over the Continental Divide, over several very steep passes.
  18. craze1cars
    craze1cars Well-Known Member
    I see this as a way to stabilize engine rpm to a more fixed level, if that’s important to you. For random example Instead of the engine rpm varying from 2k to 4,500k RPM thru the climb, you lock it into 3,250 instead. Assuming you’re in HV mode anyway, I highly doubt it saves any fuel, or uses any extra fuel, or adds or detracts from engine life at the end of the day...
    You’re being proactive and telling it to rev higher early and hold it there, with no peaks and valleys on the rpm chart. Otherwise if HV charge is not used the car is being reactive, and may at times rev higher to replace lost charge since it didn’t realize how long this hill is turning out to be.
    An interesting preference if one should choose to try it. I see nothing to gain and nothing to lose...
  19. neal adkins
    My car (even at near full soc) on this particular long climb didn't perform that great after just a few miles. It was struggling to maintain the 65mph. I saw this on several trips up this grade. I tried sport mode in ev and hv. Same result.
  20. neal adkins
    One member has complained about battery degradation. He does 2 or 3 trips up a grade each day. Mostly uses electric.
