Avoid Siemens US2:VC30GRYU charger
Discussion in 'Clarity' started by brady, Mar 4, 2018.
  1. brady
    brady Member
    https://www.amazon.com/gp/product/B00MFVI92S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    The is one of the most popular chargers on Amazon. However, I am on my 4rd one as the J1772 charging handle that plugs into the car will eventually malfunction. There is an orangish rubber seal inside the plug that gets displaced and eventually the charger wont fit into the charging port on your car. Its a serious design flaw and save yourself major headache and buy something else. I can not believe this company hasn't been sued yet.
  2. Mitch Gibbs
    Mitch Gibbs New Member
    Bummer. I've had mine for three years and it's been rock solid.
    Sent from my Pixel 2 XL using Tapatalk
  3. Ken7
    Ken7 Active Member
    Although I have a different charger, mine has that same seal inside the charger.
  4. loomis2
    loomis2 Well-Known Member
    I have had that charger for almost six years now and I have never had that problem.
  5. bpratt
    bpratt Active Member
    If you only charge while inside, why don't you just remove the rubber seal? I did on my Jekayla L2 40 Amp charger.
  6. Ken7
    Ken7 Active Member
    I'm not sure if it would really make any significant difference in terms of the ease of insertion or removal. The resistance when you insert the charger is felt almost immediately, well before it hits that ring. Similarly, upon removal, the resistance is felt throughout.
    brady likes this.
  7. PHEVer
    PHEVer New Member
    Hmmm....I purchased mine in the summer of 2017. My unit does not have the orange rubber seal. Maybe that was Siemen's solution...remove the part completely?
  8. brady
    brady Member
    I got my new charger and it seems like the internal gasket has changed. Hopefully this does the trick.
    Domenick likes this.
