auxiliary heating/cooling deactivated
Discussion in 'Cooper SE' started by endquote, Sep 23, 2022.
  1. endquote
    endquote Well-Known Member
    Curious if others have seen this warning. It's come up a few times for me in the past ~year with no explanation. Haven't noticed any ill effects.
    It seems like it has something to do with preconditioning, but I've never used preconditioning. I have the charging window set to be 100% at 2am.
    This warning came up yesterday morning, the car was not plugged in.
  2. bmartinez028
    bmartinez028 Active Member
    I’ve seen a similar message when I pull into a DC charger at a low low state of charge and try to activate “comfort climate” while charging. When this happens there is no AC function. It disappears and the AC works normal once I unplug the car and drive off.
  3. pictsidhe
    pictsidhe Well-Known Member
    The AC system is shared with battery cooling.
  4. AndysComputer
    AndysComputer Well-Known Member
    I have had the Mini refuse to fire up the cabin cooling when at low a state of charge at a fast charger.
    Essentially the cooling system struggles to cope with the task of cooling the battery doing charging AND the cabin. In essence it seems undersized.
