Auto Climate Control Temperature Setting
Discussion in 'Clarity' started by toronto_clarity, Sep 24, 2018.
  1. toronto_clarity
    toronto_clarity New Member
    When you use the Auto Climate Control feature either with the key or the app what temperature is it set to? Can we customize it to our liking? Wasn't able to find this info in the manual or may be I missed it.
  2. megreyhair
    megreyhair Active Member
    The system will use whatever setting you had it set to when you left your car. Just be aware that the system won't turn on if the temperature difference between inside the car and outside weren't big enough.
  3. Emanuel Green
    Emanuel Green Member
    KentuckyKen and iluvscuba like this.
  4. KentuckyKen
    Here is a document with more info and a chart showing the temperature ranges that the remote climate control uses. I forgot who originally posted this.
  5. dalbeck
    dalbeck Member
    PA
    Interesting to read this. I can't recall now if it was online somewhere or the dealer told me this, but I was under the impression it would either heat or cool to 72 degrees no matter what and that number couldn't be changed.
  6. insightman
    Show me a dealer who understands the Clarity Plug-In Hybrid and, and, and, what am I saying? There is no such person.
  7. Bas
    Bas New Member
    Now let's hope that Honda would update their app, so it also shows us cabin temperature, even when the climate is off. Because that's what you want to know before you use the remote climate control functionality.
  8. AnthonyW
    AnthonyW Well-Known Member
    Amen Bas, Amen.
