Gotta do some cleaning up, but the basic frame of my rack is done. Wiring is done. For those interested, I included the grommet hole also.
Please try again to insert your photos. I see only broken image icons. I'm very curious to see what your "rack" is. Thanks.
Yes, thank you. I didn't know where you had located your gear but with all that equipment, there was no other choice in a car that has room for only a 7-gallon gas tank (thankfully, Honda didn't fill that sub-trunk space with a larger gas tank--7 gallons is enough for me).
Not wanting to touch the head unit or factory amp. My assumption is the 180 amp factory amp split evenly among the four channels that each have a component system of a 6.5 inch driver and tweeter. Has anyone considered dropping a pair of 6x9s in the parcel shelf behind the back seats? I would simply remove the rear door speakers, buy a component setup and leave the tweeters and crossover in the door and run the wire to the driver in the parcel shelf on each side. I would upgrade the front door speakers as well. This would fill out the range of frequencies quite well given the available power. It would just require a bit of cutting.
