Is there a way to change the cluster display for speed from Digital to analog. Add a pointer and perhaps numbers The ring around the digital numbers appears to change with speed? I would want to keep the heads up display as digital
You can’t change anything. As you noted, the ring around the circle does indicate speed from 0 to max in an analog manner but without a scale.
