2021 Kona EV (Preferred) conversion to LED (exterior and interior)
Discussion in 'Hyundai Kona Electric' started by navguy12, Aug 25, 2020.
  1. navguy12
    navguy12 Well-Known Member
    Seen. Once its daylight here and I won't get into trouble because I woke someone up, I'll have a closer look...with my reading glasses on! ;)
    And this is what my Amazon.ca shopping cart is shaping up, for the exterior bulbs EXCEPT the headlamps, plus the 33mm interior bulbs:
    I "think" this is what I'll get for the headlamps from Amazon.com:
  3. navguy12
    Headlamps from Amazon.com have been ordered.
    Vince08: I was able to get that cover off the lamp in the cargo bay using a jewelers slotted screwdriver at the correct edge.
    Vince08 likes this.
  4. navguy12
    All exterior lamps, except the headlamps (awaiting delivery) have now been converted to LED with no fan fare:
    Front turn signals:
    Rear signal lamps:
    Backup lamps:
    ...and the rear cargo area.
    I anticipate wiring in a second unit, on the other side, to work in tandem with the single OEM fixture on the rear port side of the cargo compartment:
    Headlamps next, will attack next week when back home from a road trip. Cheers.
    Kirk, Lars, Vince08 and 2 others like this.
  5. That was quick, even for air freight! The back up lamps (#1156) curious to see how bright they are.
  6. navguy12
    The pictured products were all fulfilled by Amazon, I suspect they were in a warehouse in the Toronto area (I am in eastern Ontario).
    My 15 second test of the back up lamps in my darkened garage leads me to believe they will be more than adequate for the task.
    And I did the rear bulb swap outs with my back on a creeper...once I did my reconnaissance of the rear under chassis trim part I knew what to expect.
    Total job for all lamps concerned was less than 30 minutes.
    I am pleasantly suprised with the engineering and quality of the bits and bobs on this car...the way the chassis panels come off, the way the rear lamp housings fit into and out of their respective positions...even the clearance between the plastic inner (rear) wheel well protectors and the body sheet metal of the (rear) wheel wells.
    All very reminiscent of working on late 70s and early 80s Toyota and Honda products 40 years ago.
    ansonchappell and electriceddy like this.
  8. I find late VWs quite good as well for consistent quality throughout. BMW seem to forget about that the moment something's not visible.
    navguy12 likes this.
  9. persianrider
    persianrider Member
    Navguy how are those reverse lights or all of them for that matter in direct sunlight/daytime
    LEDs tend to be super bright at night and sometimes not so bright in the daytime
    my wife’s kona ev is arriving this coming week and I want to make the led swap as well but I’m torn between philips led bulbs which tend to be more expensive and have so so reviews
    Seeing as how meticulous you are and I’m one OCD mofo lol , I’ll definitely take your word for it if you say these are good bulbs/brightness
  10. navguy12
    I can’t give you a definitive answer as I don’t have enough data to do so. I’ll know in about six weeks with more use, but right now I’m in what I would consider the shakedown phase...and I haven’t even got the headlamps yet ;)
    But I will post results as they become apparent to me.
    Once the headlamps arrive, I’ll post my experience with the install including aiming the lamps as required.
  11. I picked up my 2021 Kona Preferred this week and this topic intrigues me. First, because my 2016 Prius already had LEDs all over, including the High/Low beam heads. When I was shopping for the Kona I noticed the Hyundai will reward you with LEDs only of you want leader seats and sunroof and 'air conditioned' seats. Second, when I took the car home and had good look all over I realized that they used left over light bulbs from the Korean war! I had bulbs like these on my 1964 Morris!
    So a plan was born to replace the bulbs i can with LEDs. I did some research and I found this site which may be useful to help us in this quest, at least a good place to start. Note the 2019 model year Kona. This need to be checked!
    https://www.superbrightleds.com/vehicle/2019-hyundai-kona-electric-vehicle-led-lights?make=34&model=4224&year=2019
    Also scroll down and read about "flashers and load resistors". My choice would be, if an easy fit (?), replace the flasher. Easier than fiddling around with installing a load resistor for each turn signal.
    Cheers
    Kirk and electriceddy like this.
  13. navguy12
    Agree ref your comment regarding load resistors.
    As per my post above...
    https://www.insideevsforum.com/community/index.php?threads/2021-kona-ev-preferred-conversion-to-led-exterior-and-interior.9430/page-2#post-107778
    ...these have all worked with no fan fare. Simple plug and play.
    I had to use load resistors back on my old 2008 Prius, big PITA...
    Kirk, Lars and electriceddy like this.
  14. Now we know here they found the light bulbs , in some old Toyotas.
  15. Last edited: Sep 5, 2020
  16. persianrider
    persianrider Member
    I installed 60W (2x 30W) led bulbs
    sure wasn't fun with the tight spot and having to install the H7 adapter for Hyundai
    final result, not bright enough at all.... the lightbeam is nice (color and the beam cutoff is perfect) but the actual light when driving isn't impressive at all
    returning the 30W bulbs, ordered 55W bulbs
    now that the adapter is in, I don't need to break my head, bought the same brand Aukee LEDs just the 55W each version, so it'll be a simple swap
    If those are too bright then I'll revert and get 45W each from them
    navguy the ones you bought are 36W each, although they fit like gloves out of the box, curious to know if the actual lighting is any good so far ? and who did you get it off amazon? I'm seeing those at 220$ the pair, hence why I told myself ill try Aukee but the stronger ones
  17. It is nice to be enthusiastic about this project, but there must be some rules regarding head lights. Not sure jumping from this watts to that watts is OK. Also, after changing the headlight bulbs the aim of the lights must be checked and, if need to be, adjusted. I absolutely hate to be blinded by cars driven with miss-adjusted lights, often on old or 'suped up' cars. These are 'obvious' LED upgrades.
    For this reason I will proceed with the backup and turn bulbs for now. Once I find the right bulbs - there are too many options, and as someone said here turn signals (and head lights!) carry safety issues.
    Remember to stay a safe driver.
    Lars
  18. persianrider
    persianrider Member
    I’m well aware you can’t just slap any bulb on any headlights...hence why I spoke of light beam/cutoff ...I’ve been on car forums for the last 20 years and Have read more than enough about reflector,projector,xenon,led etc ....and the last thing I would do is blind other drivers.
    if going 55 is too much ... I’ll revert back to 45.... if that doesn’t work then I’ll go back to better halogen than stock and call it a day....that’s the magic of trying things for yourself...I don’t mind having fun in my garage trying these things and learning from it
  19. I have 55 watt HIDs, love them,definitely not too much.
  20. navguy12
    They have not arrived yet, the package is supposed to arrive at or after 15 Sep 2020.
    I bought via the US Amazon site:
    I'll post my headlamp results (and headlamp re-aiming technique, if required) once they are installed and it is night-time...;)
  21. persianrider
    persianrider Member
    Navguy I got the same set of LEDs for front/rear flashers
    I have to say I'm impressed with the build and the brightness, I find them a bit too bright though (almost blinding)
    my neighbor who's a Porsche Mechanic came by during the day and without me asking told me "I'm surprised Hyundai would put such bright lighting, hurts the eyes"
    So I'm debating swapping them out for something less bright, did you get any feedback or have the same reaction ?
    I swaped the lights to the 45W each Aukee and luckily I found a 13$ adapter kit that comes with a key that literally makes it plug and play within 15 minutes (no more fiddling with the other adapter that is a ***** to work wirth)
    One question, these LEDs come with a small box, it fits into the housing but I'm wondering if you would drill a small hole to pass the wire/box outside and then back inside ? Wouldn't it get too hot in the housing ? (obviously not in winter but summer nights it would no ?)
    FYI the LASFIT ones are using my 13$ adapter I found, I can't find your same seller btw the ones available now are all 200$+ and yours also does not have the little box, I suspect because of the wattage being 36W each, looks like anything 40W+ has a small box
  22. navguy12
    None whatsoever.
    Sorry, can't help you there...still waiting for my headlamps to arrive. Personally, I won't be drilling any holes in my wife's car, so if the headlamps turn out to be not bright enough, then the experiment ends there.
    Can you provide a link (for dissemination of information to the community)? Thanks.
    Thanks for the heads up.
  23. persianrider
    persianrider Member
    fair point on the no drilling
    Just that I keep reading reviews on people saying after 3-4 hours of driving the lights flicker, must be because it gets too hot, I'll leave it as is since it fits perfectly in there, if not, I'll probably revert back to Halogen as well but better bulbs
    As for the adapter, I'm at the office right now so restricted on printscreen but you can search below and you'll find it
    So far it fit perfectly the Aukee LED bulbs, the advertising says its made for the RCP bulbs but that's not true at all. It also looks identical to the ones your LED kit comes with
    RCP H7 LED Headlight Bulb Adapter Holders Socket Base Retainers for Kia Hyundai Accord, 2 pcs
