2020 Leaf SV plus VSP NOISE...solution????
Discussion in 'LEAF' started by ShaneWpg, Dec 27, 2020.
  1. ShaneWpg
    ShaneWpg New Member
    I have both a 2019 and 2020 Leaf. the 2020 VSP noise is AWFUL!!!!
    Any help finding the 'speaker'/generator of this noise would be very appreciated!
    Shane - [email protected]. I hope at very least to mute it , if I cannot STOP it!
  2. Electra
    Electra Active Member
    I heard someone on reddit said you can disable it with Leafspy Pro and an OBD2 adapter.
  3. NZ EV
    NZ EV New Member
    On the 2020 leaf the VSP speaker is located just behind the front number plate. It cannot be disabled using Leaf spy.
    It is fairly to just reach in the front air intake and just unplug it but you do end up with a warning light in the instrument cluster.
    If you want the light to go away wire in a 4-6 ohm resistor in the place of the speaker. Use a resistor of enough wattage. 5 watts should be enough.
    KENNY likes this.
  4. Jan Galkowski
    Jan Galkowski New Member
    Huh. I rather like the sound.
  5. marshall
    marshall Well-Known Member
    When I first hear it, I thought there was something wrong with the car.
  6. Buzzard8080
    Buzzard8080 New Member
    I have a 2020 Leaf SL plus and I was able to turn off both sounds using the LeafSpy app. I had to purchase an ODB-II wifi scanner tool as well. It was pretty simple. I spent $45 in total but well worth it. I was sick of the reverse sound.
    KENNY likes this.
  7. Kayle Clements
    Kayle Clements New Member
    Using Leafspy (beta version) for my 23 does not turn off the sounds. I purchased a LELink^2 unit and I can get LeafSpy to see the Leaf, just changes have no effect. Is the wifi scanner tool the same idea as the LELink? One that plugs in under the drivers side steering wheel?
  8. Takophiliac
    Takophiliac New Member
    Can confirm, unable to disable the VSP noises. It would seem Nissan added some software to detect if disablement had been requested and to re-enable it if so. Drove slowly in a straight line while disabling it and it does disable, for about 3-4 seconds and then it fades back in.
  9. ShaneWpg
    ShaneWpg New Member
    Found the solution! LeafSpy Pro plus Ob connector. AWESOME!
  10. ShaneWpg
    ShaneWpg New Member
    Definitely worked THANK YOU!
