12 volt accessory ports are not working
Discussion in 'Clarity' started by Hi.Ho.Silver, Dec 24, 2018.
  1. Hi.Ho.Silver
    Hi.Ho.Silver Active Member
    Both my front and rear seat accessory ports (cigarette lighter) are dead. Do these have fuses somewhere? It’s possible that a defective phone charger caused the problem.
  2. KentuckyKen
    Try first in Fuse Box A which is one of 4 under the driver’s side dashboard.
    #10: CTR ACC SOCKET 20A
    #29: FR ACC SOCKET 20A
    Always replace with same size fuse and never ever with a larger one or you risk a melt down and possible fire.
    See p 556 in the manual for a picture of it and location of the fuse label to match fuse # with physical location.
    You’ll have to stand on your head or do a contortionist act though. Hope you’re young and supple
    Merry Christmas.
    Here’s a screen shot of it.
    Viking79 and JJim like this.
  3. insightman
    JJim likes this.
  4. Hi.Ho.Silver
    Thanks to Kentucky Ken and Insightman for the info. I'm afraid that I am neither young nor supple so this will be an adventure.
  5. MNSteve
    MNSteve Well-Known Member
    Or the PDF version,
  6. jdonalds
    Another view
  7. Hi.Ho.Silver
    Thanks for the info. I was able to locate and change the fuses which are under the dash. Basically one must lay on the ground (or on a nice mat as I did) with their head and upper body in front of the drivers seat to be able to view the fuse box. Their is "one of each" spare fuses inside the cover of the fuse box that is under the hood. If you need more (as I did) these are ones to order: ATM-LP
    KentuckyKen likes this.
