The physical dimensions for the Tesla Model Y are now out, along with weights.
- Exterior Dimensions:
- Overall Length: 187 in or 4,750 mm
- Total Width:
- * Overall Width including mirrors: 83.8 in or 2,129 mm
- * Overall Width including folded mirrors: 77.9 in or 1,978 mm
- * Overall Width excluding mirrors: 75.6 in or 1,921 mm
- Total Height:
- Overall Height: 64 in or 1,624 mm
- Curb Weight* Long Range Battery, Dual Motor: 4,416 lbs or 2,003 kg
- GVWR** Long Range Battery, Dual Motor: 5,302 lbs or 2,405 kg
- Gross Vehicle Weight Distribution - Dual Motor: Front 46% and Rear 54%
- Gross Axle Weight Rating - Front 20" Wheels: 3,005 lbs or 1,363 kg
- Gross Axle Weight Rating - Rear 20" Wheels: 3,307 lbs or 1500 kg
- *Curb Weight = weight of the vehicle with correct fluid levels, no occupants and no cargo
- **GVWR = Gross Vehicle Weight Rating
