I purchased my Kona in August and now have about 6K miles. Last week, my car had a range of 270 miles at 100% charge. Yesterday it had a 252 mile range at 100% charge. Today it had a 245 mile range at 100%. These numbers are with everything off (heater and AC). Obviously the mile range is decreasing. I assume this is not normal?
The numbers "are with heat off" but realisticly, you've been using defrost, heat and/or seatwarmers etc. lately, right? My guess-O-meter (predicted range) is not really worth reading lately, because I drive on short trips around town in a cold car. Obviously I don't want to sit inside a lump of steel below the freezing point, so I turn on the heat, drive 5 miles, get out, do something for half an hour, and the car cools down. I get back ind drive away, again with the heater blasting. About the time I get home again, the car is comfortable and I shut it off and leave it in the cold driveway.
After a few days of this, the guess-O-meter concludes that I drive everywhere with the heat blasting, which (look at the efficiency numbers for the current drive) really eats up the battery.
But now what if I'm planning on a long highway drive to join some family for Christmas? Obviously in a multi-hour drive where the range actually matters, I don't continue blasting the heat. The car warms up and I realize I should wear my hat and cabin environment ceases to be a giant load on the battery (except briefly at the beginning of the trip.) The guess-O-meter will likely underestimate my range quite painfully, based on my previous behaviour.
Have I got this wrong, folks? This is my first winter with an EV. I am assuming I can't apply estimates based on one kind of driving when I'm doing another kind of driving. If E-Ticket goes to the dealership, they're going to actually test the battery and tell E-Ticket that the battery is fine, aren't they? I'm pretty sure this apparent range drop is an illusion based on in-town winter driving. Or at least it is for me.
