@Dusty just reported a confirmed bearing failure. I believe this is the first example of a
rear bearing failure reported here.
Thanks for including the audio... I believe failed bearings can have different audio signatures, but this certainly demonstrates what it could sound like.
Another note - We have learned that the Clarity uses the same front bearing (and Hub) as the Honda HRV. This is good from the standpoint of future part availability. I have not been able to find any such commonality with the rear bearings, so they may be Clarity-specific...
@Dusty - Has your vehicle been repaired? or will there be a delay before a new part can be obtained? Did your dealer convey any information about part availability or commonality with other vehicles?
Thanks for reporting your experiences here !
List below updated as of 11/29/2019:
@AnthonyW (no indication of which one)
@Hypomania (right front)
@PascoClarity (right front)
@MDClarity07 (right front)
@Groves Cooke (left front)
@Exro (left front)
@FtbChrisBs (left front)
@Dusty (left rear) - Manufacture Date 4/2018
Here are a couple that are unconfirmed, or initially misdiagnosed:
@HEEKANG OH Reported symptoms, but did not report back on resolution (if any)
@tterag (initially suspected left front, but turned out to be bad transmission after much agony diagnosing it)
