Paul DeLeon
Has anyone tried the Tesla adaptor? The Lectron or Tesla tap?
There are not too many useful charging stations near me, except one Tesla.
I have seen YouTube reviews, but that's it. I believe that these things are for destination chargers(hotels, etc), and not superchargers.Has anyone tried the Tesla adaptor? The Lectron or Tesla tap?
I would have run the conduit vertical out of the panel and then bend right to avoid one 90 degree bend, but that's just me. Nice color and very shiny Kona.I have a Tesla Tap and use it with my telsa charger I have installed in the garage. Whether charging a tesla or my Kona I am able to charge using the same charger.
It is very sticky and almost difficult to remove the Tesla charger from the Tap.
Yeah I plan to only use it when absolutely necessary at a destination charger. Specifically in WV I'm stopping somewhere that I know I'll have to charge and there are 3 Tesla destination chargers and 1 J-1772 charger. I don't want to hang my whole trip on that 1 charger being operable and available. I'm staying overnight so I'm not THAT worried about available, but operable? That could be an issue.
I have heard the Tesla DC charger doesn't recognize konas etc. electric cars..So those adapters only work on level two tesla chargers but not tesla DC chargers right.
That is correct. Level 2 chargers only. At this time there are no adapters For DC fast charge to CCS. There is a Tesla to Chadmo adapter but its only works for Tesla it is of no use to a Kona.
The best way to determine which chargers are available is to use plug share. https://www.plugshare.com/ It allows you to specify by charger type. In plug share select the Tesla charger but not the Supercharger and not the Tesla (Roadster) It will then show all the Tesla level 2 chargers where the adapter will work.so just to clear my mind the adapters are designed to work all the time on Tesla 2 chargers The Tesla public chargers you see on the highways etc are they all DC chargers or a mix of 2's and 3's. Thanks for the help.
Would only be beneficial if you have frequent access to a Tesla destination charger, here is the map:Looks very interesting as I did not even know this existed. But at around $200 it is a bit too pricey for me unless I absolutely needed it.
I didn't know about it, either. But I plan a big trip next month and I was at a free charger the other night that had 1 Tesla and 1 J-1772 charger and of course there was 1 in use... a Tesla was using the J-1772 charger so I was stuck. That got me thinking and I decided it might be handy to have the adapter with me in cases like that, not to mention the long trip next month. I think in the long run it'll totally be worth it, but $200 does seem a bit ridiculous - agreed.Looks very interesting as I did not even know this existed. But at around $200 it is a bit too pricey for me unless I absolutely needed it.
