I have been seriously looking in to using the Kona as a back up power supply. I currently have an older grid-tied solar system which means that when the grids down so are my solar panels. To change to a battery back up would require a number of changes and would easily cost a minimum of $4,000 us dollars. I also have a back up generator with an interlock system so that I can plug it in to my electrical panel and power my house, garage and guest house plus my well pump.
As I said in my previous post I don't want a generator running continuously for minimum power times. So I have been looking at using the Kona and an inverter. (Side note: Nissan has been actually working on a unit which would allow a Leaf to plug in to a house ( don't know if it would work for other EVs
https://electrek.co/2017/10/04/nissan-ev-ecosystem-free-power-leaf-vehicle-to-grid/ )).
So I have been researching inverters that would work with my generator interlock plug. What I have found so far is that there are many types of inverters. There are the basic hook to your car battery inverter which allows you to plug items in to the inverter. These work fine for powering small items like lights phone chargers even a refrigerator ( my refrigerator uses 800 watts to start and 150 watts while running. I have my utility panel wired to monitor my loads so I know what circuit uses how much power for how long)
https://smile.amazon.com/Emporia-Energy-Expansion-Electricity-Guesswork/dp/B07XYJCDYT/ref=sr_1_1?crid=GJ8INKHRNV6L&keywords=emporia&qid=1572996230&sprefix=enperia,aps,786&sr=8-1
Then moving up to higher powered inverters (things that will run washing machines and well pumps ) there are three types. Square wave , modified sine wave and Pure Sine wave. Of these I am only interested in the Pure Sine Wave as it has the capability to emulate the power from the grid. Since I want to tie into my house I want 120/240 volt. The inverter will need to be split phase (120 volt/ 240 volt with a zero potential between neutral and ground. Some cheaper inverters have 60volts between neutral and ground. These are a couple of the inverters I am considering
https://www.sigineer.com/product/30...0vac-double-phase-pure-sine-inverter-charger/
https://www.aimscorp.net/4000-Watt-12-Volt-Pure-Sine-Inverter-Charger-120-240.html
I am considering two operating scenarios. One I would be turn off all of the higher powered loads in the evening and just run the low loads directly form the Kona in the utility mode. The second is to use the Kona in the utility mode to charge one of two battery banks and alternate battery banks as needed ( I have battery's from multiply vehicles most of which aren't being used most of the time any way(truck, tractor, motor home...).
My next step is to finalize the inverter purchase and then run a number of test. I will post more after I start testing.
