Jamas
A warning to those that live in regions that require a front license plate. I came out the other day and noticed that my front plate was missing. The plate was secured by two screws in the top to a plastic plate holder. It looks like the holes in the plastic holder were somewhat stripped, so probably wasn't holding the plate very securely. I had to file a police report and then go to DMV to get my old plates cancelled and receive new ones. I now secured the front plate with plastic ties. I also drilled a couple holes underneath the plastic holder and used two additional plastic ties on the bottom of the plate as well. When it stops raining here, I'll probably spend a little more time making them a little less visible, but they're doing the job for now.
Bottom line, if you have front license plates, make sure they are securely fastened.
