I am considering purchasing a Tesla next year, and was also initially perplexed about the perceived need for a charging station (as promoted by auto manufacturers and aftermarket accessory suppliers). Here are some preliminary thoughts and conclusions. I'd be glad to hear other viewpoints.
The amount of power supplied to the car being charged at home and the rate of charging are, I believe, factors of the household electrical circuit you use. The household circuit consists of (a) the initial design of the circuit at the electrical panel (inside the circuit-breaker box where electricity enters your house), (b) the power rating of the circuit breaker you choose, (c) the gauge of house wiring used (e.g., Romex 6-3 w/ground wire), and (d) the particular outlet (e.g., NEMA 14-50) or hard-wired charging station used.
Based on what I’ve read, to charge a car at a reasonable rate you usually want to use a 220/240-volt circuit (similar to that used for clothes dryers, electric ranges, and hot tubs). But to get an adequately fast charge, you also want reasonably high AMPERAGE (e.g., ~60 amps). (Of course, you should follow the auto manufacturer's recommendations.) If you already have an adequate circuit and accessible outlet (say in the garage) with sufficient voltage and amperage, that is great. But if not, you need to install an adequate dedicated and accessible circuit (probably using a professional electrician).
ALL THIS IS TRUE WHETHER YOU USE A SIMPLE WALL OUTLET OR A CHARGING STATION!
View attachment 6514 View attachment 6515
The electrical power (voltage and amperage) available to charge your car is
not determined by the charging station or outlet alone. It is determined by the electrical circuit (inside your walls) that the charging station or outlet is attached to.
So assuming you have or install an adequately-powerful dedicated circuit, what is the advantage of a $500+ (Tesla, ClipperCreek, or other) charging station over a simple outlet?
Here are possible advantages of a (hard-wired) charging station that I can think of:
- Appearance. A charging station is neat and tidy and looks professional. But so, also, does a properly-installed outlet. A standard outlet is simpler, smaller, and usually easier to install.
- Weather-proof and locking charging stations are available. But so, too, are weather-proof and/or locking outlet covers (which are much cheaper).
- A charging station probably comes with a permanently-attached charging cable that cannot be easily removed (i.e., stolen). In comparison, a simple outlet requires that you already have, or need to purchase, an adequately-sized, detachable cable with appropriate plug (to attach to your 240v outlet). And new cars may come with suitable charging cables/adapters, so you may not need to buy one.
- A charging station may have a built-in hanger to keep the cable neatly stored.
- Since it is usually installed by a licensed electrician, presence of a charging station and an installer helps ensure that the electrical household circuit powering it is adequate and safe (i.e., meets local code and the auto-maker’s requirements).
- Newer, more expensive charging stations may be rated for higher amperage (e.g., >60 amps), and thus charge more quickly. However, keep in mind that a charging station CAN ONLY dole out the electrical power supplied by the household circuit behind it. An adequate electrical outlet at the end of the same circuit supplies the same voltage/amperage as a charging station.
- Newer charging stations my include WiFi capability that can, I assume, provide the car-owner with helpful charging information and convenient functions.
- A charging station should safely charge and shut off (e.g., to prevent overcharging), have features liker timers or trickle-charging, and may contain an internal fuse or circuit-breaker. But I assume that today's cars may have those features built in. And if the household circuit is properly installed, additional circuitry safeguards may be unnecessary.
My Initial Conclusion: As long as you use an adequately powerful and properly/safely installed household electrical circuit (which is required no matter what), an additional charging station seems superfluous to me, and therefore is probably
NOT worth the (often) considerable additional expense to purchase and install, especially if your vehicle has built-in charging capabilities and safeguards. The bulk of your charging-preparation expenditures should instead be directed towards installing an adequate and safe (up to code) house circuit using a proper 240-volt outlet (e.g., that matches the plug of the cable your car comes with). This would be necessary whether you just install an outlet or go the extra mile and also buy a (costly) charging station.
What do other people think?
