FloridaSun
My wife's van now has over 200k miles and it on it's last leg (despite no codes appearing on the dash) and it will be time to replace it. I really don't want to spend an arm and a leg on a replacement, so even a used Bolt is out of the question. (can't find one under $20k) . She needs at least 150 mile range, and the only affordable BEV would be a Leaf, but the older LEAFs only have sub 90 mile range. I was thinking in getting a used Volt for her. She usually drives less than 40 miles in a day but sometimes, the drives up to 120 miles which would eliminate the LEAF. Is there any other EV or PHEV choice that can be found under US$ 10k?? The good thing about the VOLT is that it won't take long time to charge and I won't have to worry about the draw on my home's electrical systems of 2 cars charging at the same time.. My wife could charge first and then I charge my Kona.. We wouldn't need both cars hooked up at the same time and my EVSE could reach both cars in their respective spots in the garage.
