Supplies 14.4V while the car is in run mode, definitely recommend using battery saverso you don't need to use utility mode if you have battery saver on!
If you want a mysterious alarm [emoji12]
Push menu button on steering wheel, User settings/Other/ (top of list - Battery saver+) / enable.@electriceddy is battery saver mode an option,if so,where do you turn it on ?
@KonaTom , utility mode's something we can control, turn on.
Mine has come on now once every two months after sitting overnight, unplugged.What I can't find info.on is what is the "normal" operation for this auxiliary battery saver mode for the 12 V? I read it happens when the 12V gets lower than it should? Wondering if I have a failing 12V if every two months is abnormal for the auxiliary mode to run.I also don't get that driver display message"Aux.Battery Saver + was used while parked. Would notice it because the ready drive displays in the same area post start. View attachment 6250
geesh, i have NEVER had the alarm.Whatz up with all this weirdness from our otherwise fantastic EVs? Thing that bugs me,the owner's manual doesn't expand on the event so owners know to be wary , or ignore because it's "normal." @Wildeyed shouldn't find out the hard way that maybe their scenario wasn't "normal,"and should have received a dash alert like the master warning light [triangle, exclamation inside] to visit the dealership.Especially with the resulting DTC codes.I've never seen the message in the display either.
However, I've had that weird alarm that nobody knew existed. The alarm only stopped after I turned off the battery saver. After a couple days I turned it back on and never had the alarm come on since.
That depends on the phone manufacturer! [emoji12]As cars become more technologically sophisticated, manufacturers should really up their game by having software development teams as good as phone manufacturers.
