HondaLink App Update
  • Thread starter Thread starter vicw
  • Replies Replies 270
  • Views Views 94K
My Android phone displays a limited number of notifications. Do you think it's possible that in some cases it sends a notification that charging has stopped but by the time you look at your phone other notifications have come in and the charging notification is no longer there?
In my case, I check my phone quite often, and therefore, do not have many notifications lingering around.
My car not only sends a notification when charging stops, but it also plays the sound I told it to. It did it on my Android phones, first my S7 Edge and now on my S10+.
Interesting. Maybe the sound is not turned on my default or something on my phone is blocking it. Let me check.
"Forgot to mention using LineageOS 14.1 (Android 7.1.2) on an old Nexus 5" == Running a non-standard version of Android on old hardware is not something to mention in passing when questioning why your app doesn't fully function.
New update to the HondaLink App dated July 19, 2019
Whats New:
• Improved reliability of remote commands.
• Minor bug fixes and UX enhancements.
• Improved map search results.
Recently got a Clarity, and installed the app on my iphone. The app does not show me the car is charging or getting any notifications. Logged back out and back in. I've been reading a lot about how useless this app is, but didn't realize to what degree.
It has worked for me for 2 years. You should call Honda Support.
I just updated the Android version of the HondaLink app. I'm not at all bothered by the loss of the infamous EV Charge percentage, but I am concerned with the persistent Notification that HondaLink is Connecting, with the only option being to Dismiss it. The data shows after I Select Dismiss, but after I exit the app, the Notification continues. Even if I select the Notification to be minimized, it still persists.
That looks like a possible battery drain issue.
I just noticed that in Settings/Apps & Notifications/App Info for the HondaLink App showed a double Notification selection - both shown active. I turned off the second one, and I'm not seeing the persistent notification. Not sure what other effect that may have.
Please don’t hate me, but my app works fine on iOS in all its rudimentary glory. You do have to go into settings and enable notifications and cellular data if you want a status update when you aren’t in Bluetooth or wifi range. And your phone has to have been paired with the vehicle. I would suggest that if you are in range of your wifi, that might be an alternative way to link with your phone. I wonder if a lot of these issues have to do with phone privacy, notification and cellular data settings.
Is the loss of battery % an Android thing? On my iPhone, I get a useful display of percentage charged, gas tank level and approximate miles for each. I don’t have to be plugged in. I have set my car to charge every night at 11pm, and if I go on the road and charge elsewhere, I must disable the automatic charge or it won’t charge at a station. I can see the charge level change on the app while it’s charging, but this happens sooooo slowly.
View attachment 4159 Here’s a bug they didn’t fix. Battery level shows blank if I don’t plug the car in. Doesn’t happen all the time - but happens pretty often.
Check your notification settings on your phone, whether you are connected or paired via Bluetooth, wifi or cellular data. Then check your settings on the car. Conflicts between the two can cause the app to appear to malfunction. Good luck!
It'd be nice to figure out the pattern/issue. I've had my Clarity since May 2018 and I have the occasional glitch, but it has always sorted out within a day or two.
With the latest update, I lost the ability to "Turn on Climate" remotely.
It says communicating to the car, waiting for response and
then times out and returns to the home screen.
Android app and Base clarity if that matters.
For all its engineering prowess, Honda has the worst app development team.
Version 4.0.7.1 came out nearly two weeks ago so I don't think the problem that started Tuesday for many people is related to the app update, since it worked prior to Tuesday. It is more likely a problem on the Honda server side. We also don't know yet if it affects everyone or if like the previous problem it only affects some accounts and some people's still works. Naturally the people who come on to post about it have the problem, but like last time we may hear from someone that it still works for them.
Unfortunately it's now Friday evening and so I don't expect them to fix it any earlier than Monday.
Possible, but the app update was not great either. Didn't fix the lack of notifications or anything else that I can tell.
Somewhere along the line, I lost the ability to ability to change the Charge Schedule on the Android app, version 4.0.7.1
If I select Schedule Charge, then Modify Schedule, I can adjust the start time, but after I select the Check, to process the change, it just spins its wheels, and eventually reports that it encountered an error, and the start time stays with the old setting.
Several people are experiencing the problem, it seems to have started on Tuesday. It basically seems to be round two of a similar problem that lasted for a few days a couple weeks go. Posts about the current problem start in post #66 of the original thread.
https://insideevsforum.com/communit...vehicle-honda-link-app.6769/page-4#post-77366
As I assume you know you can still change the charge schedule using the in car menu. And it seems like even though you can't change the charge schedule with the app, the app does display the current charge status on the home page.
Got the car in August it last year. Never had a problem with the app until recently when it stopped working for everyone for a few days.
After the latest update, the app shows charge status however remote climate doesn’t work.
Be sure to call Honda.
