I fund this to explain it. ALSO I have an EVSE spy using that tells me the max amps even when my spark EV just pulls 12 amps.
QUOTE=Simply put, EVSE is a protocol to help keep you and your electric car safe while charging. Using two-way communication between the charger and car, the correct charging current is set based on the maximum current the charger can provide as well as the maximum current the car can receive.Oct 28, 2010
