The only things missing:
- Which trim?
- Did it come with a spare?
- Which trim?
Our 2003 had a donut spare that I replaced with 14" full size spare. The 14" spare worked for tire size experiments:a feature No New Tesla has
I bought a full size, 15" spare for the 2010 Prius. The 2017 Prius Prime came with a goop kit and jack but I had the full size spare from the 2010 for cross country trips.
- rear tire is OEM and even after four wheel alignment, the car had neutral stability
- front tire is next size up that improved straight-line stability and corrected speed and odometer
- spare tire is experimental for front wheel overdrive
The 2014 BMW i3-REx was missing its goop kit which I replaced with a string plug kit and Harbor Freight air pump. One rear tire picked up two punctures, a machine screw and conical shaped, stone. The string repairs worked but the second plug had a slow leak. Redoing it worked fine. With 34,000 service miles, the worn out tire was replaced a couple of months later:
The string plug kit is messy so I added some disposable, rubber gloves.
For the Tesla and BMW, I carry an automatic, 12V air pump and this:
The plugs are glue free and the mushroom head is mechanically superior.
Perhaps it is time to rethink making backhanded comments about a Tesla in the thread. Regardless, if someone gets a clue from my tire experiments, good. If not, good too.I certainly do not care
So far, the Tesla remains straight-line stable and with the driver assistant systems, very well behaved. For example, it handles curves and ramps 'hands free.' It also makes lane changes with just the turn signal. Well with the cool weather, time to air up the tires.
As for that plugged tire, there was no noticeable vibration. Had the tire developed a slow leak, I would have taken it to a tire shop but it was already getting close to the wear bars. The 'Plug and Go' kit has amazing, light plugs. It comes from the motorcycle world.
And I am quite satisfied with mine. Drove about 50 miles today with most just for fun.Bob, Tesla builds Beta products . . .
It is a dirty job and I'm glad you're up to it.As for the tire vibrations, I am pretty sure you do not drive as fast as I do, and not as sensitive to the vehicles mechanicals. . . .
Considering the quality of roads in Dixie, it is a wonder anyone could tell what was the problem. I used to listen to electro-tech music until it began to sound like something was wrong with the engine. I once fixed a failing valve chain by turning off the music.
