victor_2019
this is the second time I notice this. car is a couple of months old.
first time it happened with the 120V trickle charger. it just stopped charging around 80-something percent even though it was set to charge to 100%.
and today I set the limit to 90%. I charged from about 15% to about 40% on a 240V L2 charger, then because it was taking too long I switched to a 50kW DC charger until about 70% and then went back to a 240V charger (these are free chargers at work).
then I looked later on at my bluelink and I see the car at 75%, it says it is plugged in but the remaining time is not showing.
so I go down and the car charging port is not lit up, the battery sign is not flashing. inside the car it is not showing anything on the dash when I open the door, does not show that it is plugged in (but bluelink does).
charger doesn't show any errors. car doesn't show errors either.
and then I turned the car on and it started charging again on its own. I did not touch the charger or the cable connection, just turned the car on.
it's about 21 degrees C outside.
bluelink is now showing 2 hours left to 90%.
anyone else see something like this?
