MajorAward
No I never get past the "Connection Required" screen. Following what you did I was in my house, not connected to the car, I searched a destination (you can't just browse the map and point at something, you have to do a formal search). I clicked "Send to Car" and instantaneously got a message "Connection Required", I mean my finger hasn't even left the screen and I get the "Connection Required" message. It's the only fast thing I have ever seen in the app which makes me think the bug is right there, I suspect it is not actually checking for a connection but in the software code something trips mine immediately to the "Connection Required" screen without even checking for a connection. Does your "Connection Required" screen come up instantly or does it look like it at least tries for a few seconds?
Anyway while I was still on the "Connection Required" screen I walked out to the car and turned it on. On the app without me doing anything it then changed to "Connecting" with a Dismiss option and then sat there for about a minute then that screen went away and I was back where I was on the "Connection Required" screen, and that's it nothing else happens. I never see anything happen on the car display. I waited about five minutes and nothing.
As I mentioned the "Connect" screen with Dismiss option always appears whenever I open the app while in the car (with the car on) and after a minute it always returns to the screen where I was, so I don't think it's actually related to the send destination function, it's just what the app always does when the app detects that I am in the car. What it does I think is nothing because as I mentioned I can use my phone with the car, proving that I am connected (via bluetooth, not plugged in) and then launch the app and I always get the "Connecting" screen even though I know I am already connected, and since I know it does nothing instead of waiting uselessly for a minute I click Dismiss and do whatever I was going to do in the app. Although I rarely use the app in the car I am just saying what happens anytime I have used it in the car. This time of course I did not click "Dismiss" just in case but after a minute it went away like usual and nothing happened.
The things that I use the app for like schedule charge or turn on climate I know work through cellular network because they work whether I am in the car or away from the car. Sending a destination to the car however apparently uses bluetooth, but it doesn't work for me because for some reason it thinks I am not connected to bluetooth even though I am. If I go into settings on the car display I can see my phone listed as connected.
Maybe there are settings in my phone that need to be changed but no way I am going in that deep, even if I could get it to work like you said I don't see how this is any advantage. I guess the idea is if you are in your house or restaurant you can pull up the app and search your next destination, then send it to the car. But if it isn't available in Nav until several minutes after you get to your car, then what's the point. However I did think of one use, the built-in Nav database can get out of date pretty quickly, but presumably the app is connected to a current database, so maybe you can find a location in the app that you can't find in the Nav screen, s so then you could send it. Still not great having to wait several minutes though for it to show up.
Also for reference I am using a Samsung Galaxy S9+ with Android 9
Try this way. If it doesn't work, I think a setting in you phone may be an issue.
I decided to see what would happen if I used the HondaLink app to send a location to the car, got in the car and turned it on, then did nothing else. So on the phone HondaLink app, I pressed "maps", then pressed "search here", then pressed the "food" icon, then chose a random restaurant from the list.Pressed the restaurant name, then pressed "Send To Car".
Of course "Connection Required " appeared, and stayed on the screen until I got in the car and swiched on accessory mode. After that, "Connecting...'' along with the "dismiss" button displayed on the app screen for about 30 seconds, then the app screen changed to "Connected to 2018 Clarity Plug-in hybrid" (or whatever you named your car in the app), along with the "dismiss" button at the bottom. I decided to just wait. Four minutes later, I heard the sparkle sound, and my "place" icon appeared on the console screen. Swipe down, press "Zoe's Kitchen" or whatever your choice was, and Bob's your uncle.It may be faster to press "dismiss" at this last step, then press "I'm safe", but either way the place is sent to your car...
On another note the Find My Car, and schedule charge worked well. I haven't used the schedule climate feature yet.
Hope that helps.
