Strange ICE behavior
@M.M.
Tbh, it really doesn’t matter how the Clarity, or any EV works. Getting to the bottom of the problem is not needed, as long as a fix is provided in some manner. In reality, it is burning excess fuel that wasn’t needed. I know for a fact that the Volt does not do this.
If it is a design flaw by Honda, it needs to be fixed. It’s that simple.
No they shouldn't, the EPA range is 0 to 47 miles.
I agree it should be changed, but the car is a PHEV and not an EREV.
Another post says the Volt does not do this. If so, it is virtually the same technology as the Clarity. So what gives?
I agree, the Clarity should drive like the Volt. However, Honda decided to make it a hybrid with EPA 0 to 47 mile range instead of like the Volt, electric vehicle with EPA 53 mile range and then switches to gas.
I am just saying Honda isn't doing anything wrong per their EPA range, but we should push them to see if they can disable engine starting while full within some margin. Like driving down short hill shouldn't start the engine, but maybe driving down a mountain would (Volt has issues after around 0.5 or 1 kWh added in regen while full).
I need to report another strange ICE behavior.
The batt was near full. Car in EV mode. Climate control set to 70F. City traffic. ICE came on and the blue ring turned white in dash. ICE ran for a few minutes. Stopped when I stopped at a traffic light. It never came back on again during that trip. But the ring never change back to blue. I toggled the mode mode a few times and the ring did a partial blue ind HV mode. But turned back to white in EV. The strange thing is that the ring ever changed back to mostly blue.
I'm so glad I'm not the only one seeing this issue. I agree with jerry50902 in that if Chevy has found a way to not run the engine when the battery is full then Honda should be able to do the same. I'm going to reach out to my dealer but I don't have a lot of hope as the sales guy didn't know a lot about the car and when I dropped by the service department (SiriusXM not working) the guy that met my car didn't even know what model I had (he thought it was an Accord but was confused because "it didn't quite look right"). I love the car, it's so much roomier and comfortable then our Volt and the ACC/LKAS are pretty amazing but disappointed in the drive train if this can't be fixed.
I talked to a couple of knowledgeable co-workers and did some additional research and can at least shed a little more light on what other cars do in the "full battery downhill" situation.
Nissan Leaf
As a full EV, these will let you charge the battery to true 100%, and can also be programmed to stop at 80%. My co-worker who lives at the top of a long hill and owns a Leaf informs me that if you charge to 100% then go down a long hill the regen will just quit after a bit, when the battery is in danger of overcharging, and you're left to use mechanical braking. You can feel it at that point. Telling the car to stop charging at 80% or cranking up the heater to burn excess energy are ways of manually avoiding or mitigating.
So that one makes perfect sense--as a pure EV there's nowehere else to put the energy other than the heater or brakes.
Plug-in Prius
These have a full transmission, and according to my knowledgeable co-worker they will start the engine when the battery is really full, and use compressive engine braking at that point to augment the mechanical brakes. Makes sense because of how the transmission is configured.
Chevrolet Volt
The Volt's ICE is physically capable of being linked to the wheels, but is only designed to at speeds over 70mph (full drivetrain description here). Per Chevrolet themselves, what the Volt does is really interesting. The car has a smaller 55kW motor-generator whose primary purpose is generation from the ICE, but is connected to the wheels above 70mph with an appropriate-ratio gear in order to increase EV efficiency at high speeds. With a full battery, the car connects both electric motors to the wheels and dumps energy being generated from the main motor into the secondary one. Since the motors are actively cooled (they apparently have their own radiator), it can dump about 12kW of energy into the electric motors as a means of bleeding off energy to augment the mechanical brakes without ever needing to bring the ICE online.
A forum thread elsewhere quotes a response from someone at Chevrolet explaining this. This post in that same thread is someone who actually tested this and verified it with the car's computer. The specific message:
You have come across a feature of the vehicle which protects the battery from overcharging. Under certain circumstances, the electric motors will resist one another to provide braking in addition to the friction brakes on the vehicle. In order to meet emission requirements, the Volt does not spin the engine, but uses clutch 2 in the drive unit to link both motors. When the vehicle is at low speeds, clutch 2 requires that the resultant planetary gearset speeds increase to compensate. You will hear the electric motors at higher speeds, which is certainly a change from their normally silent operation.
The Volt was validated using the steepest, longest descent in the nation, Pike's Peak. With a full battery, the volt can descend Pike's Peak without issue with a combination of friction brakes and the electric motors. This is part of the Voltec propulsion system which has many more delighting features waiting for you to discover.
Volt Advisor Trevor
Chevrolet Volt Advisor Team
(877) 486-5846
[email protected]
Clarity
This one's the question mark at this point. Since it has a mechanical transmision, it could theoretically do what the Prius does. Since the drivetrain as I understand it is somewhat similar to the Volt's, it's also theoretically possible to do what the Volt does. Or it could do the wacky third option and use the generator to put load on the ICE. Or it could just force you to rely on the brake pads like a pure EV. Which of those it actually does is anybody's guess until someone supplies more concrete info, but...
...the real question is whether it's inappropriately using the ICE to actually provide energy--rather than just waste it--in some circumstances, which is what some of the posts in this thread seem to be describing. If so, that's a bug, and should be fixed. One acceptable way for a PHEV to provide supplementary braking on a full battery is to use compressive braking in the ICE, but inappropriately generating power with the ICE is wrong behavior.
Since I don't have anywhere to charge at the top of a hill I can't really test this myself or experiment. I did try putting it in HV Charge mode with a full battery and driving up a hill, goosing it to encourage ICE use, but the car fairly aggressively used battery energy until the SOC was about 90%, and I only had enough hill to charge it back to about 95%.
Tbh, it really doesn’t matter how the Clarity, or any EV works. [...] If it is a design flaw by Honda, it needs to be fixed. It’s that simple.
That's kind of the point of getting to the bottom of it--depending on exactly what the car is doing, it might not be a design flaw, just not the behavior people are expecting. Conversely, it might be doing something logical, but doing it wrong, so it is a design flaw. I've never seen it happen, personally, but I'm curious what's going on and also figure it's useful to know what, exactly, is happening, in order to distinguish between unexpected behavior and an actual car software problem.
I'm going to post a poll to try and gather a bit more data.
M.M., thanks for the great information and starting the poll (just took it). This will certainly help us figure out what our Claritys are doing. Keep up the good work!
I think this may have something to do with the problem reported by @bobcubsfan in another thread, but maybe not.
Several exciting things happened to me and my Clarity last week.
1. My EV range hit 50 miles for the first time ever. I found this very exciting (as background, I live in Duluth, MN and consistently got EV ranges in the low to mid 20s in my first several months of ownership).
2. Last week, with early morning temps in the high 30s (daytime temps in the low 60s), my ICE came on when I pulled out of my garage. My battery was fully charged as usual (see image below).
3. The ICE frustratingly stayed on for my entire drive to work (only a few miles) just like it was winter again.
4. Strangely, even after I came to a complete stop, and the engine was off (I couldn't hear it), the bar on the speedometer stayed white instead of turning to blue. This happened again two days later. Additionally, even though temps have actually been WARMER (in the 60s regularly), I have never hit 50 miles of EV again. So, it's not just ambient temps that affect it. See engine off but only white bar in picture below.
So, what does this mean (car has acted normal for the last two days)?
1. Why did ICE suddenly turn on and stay on?
2. Why no EV driving even when fully charged?
3. Why didn't EV capability come back on when fully charged and stationary?
4. What are all the factors that affect EV range beyond ambient temperature?
I'm finding both my EV and HV range to be extremely accurate. But then again, I haven't put gas in for a few months.
- Rajiv
- Rajiv
I am new to this forum and exactly having the same issue. In normal driving conditions, just out of home whether within 1-2 miles or well over 10+ miles, my clarity keeps jumping into ICE mode for no reason. Can't figure out why its happening. Someimes it goes back to EV on its own and sometimes have to stop/restart the car to get it back to EV mode.
I see this thread was 1+ year old, what was the solution determined for this ? Anything dealer could do to address this ?
Also I keep getting weird humming noise while the battery is charging at home. Is this normal ?
Thanks all.
nayagan, your situation may not match this but it is a common cause. If you begin driving with a 100% full battery and then proceed to go down a hill the car will try to use regen to store power while descending the hill. However there is nowhere for the energy to go because the battery is full. So Honda's solution is to use the generator to spin the engine to dissipate that energy.
My situation is such that we have a 14% downgrade 1/2 mile long when driving away from our house with a full charge. However that hill is 1 mile from our house so the car burns just enough battery power so that the downhill regen does find enough empty space in the battery for that regen power. So in our case the engine doesn't start and the car stays in EV mode.
YMMV,
John
I have had the ICE come on flat if after a 100% charge I accelerate hard to end of the block then immediately do full regen. My new SOP is gently drive/slow down until I have traveled a couple of miles.
To be clear, ICE comes on, or not, with exactly the same route, temperature, full charge. Inconsistent behavior is the issue. Not that ICE comes on. Completely unpredictable.
I have observed "inconsistent behavior" on the Clarity, but I put it in quotes because I don't think it's inconsistent. The fact that we cannot predict it does not make it inconsistent.
There are many different parameters that are inputs to the software that controls how the car works. Some of them are obvious; we can't even guess at what some of them are. I am confident that the result is completely predictable if we had all the inputs because computers are deterministic.
My personal bugaboo is the gear icon. I can drive the same route at the same speed with the same weather conditions and observe very different behavior in terms of when the gear icon is displayed. But I am not privy to all the inputs. SOC has an effect, as does what the SOC was when I hit the HV button, and the net in/out of charge in the past time interval . . . and I don't know what the time interval is. I am sure that there are other factors that go into the algorithm on how to configure where the energy is coming from to propel the car. Given our inability to even know what those are, much less observe their value, it's going to look like magic to us.
I try very hard not to get upset when the car doesn't behave exactly the way I would predict.
We are a new owner. We've done a few days running EV only - enough to get our estimated EV range up to 50 after charging this morning. On the freeway - 70 mph - on the way home in EV my wife noticed that the ICE was running. As she remembers it, the energy was going from the ICE and battery to the wheels. This was only a few miles into the trip and lasted only a few miles. Fairly level west MI road. Our HV range dropped from 231 to 225.
It was around 90 degrees here today so the AC was running. Would this cause the ICE to run?
