Does it give independent cell group voltages ( IIRC 98 S cell groups of 3P) at least to give an indication of weak cells?
No it doesnt give independent cell VDoes it give independent cell group voltages ( IIRC 98 S cell groups of 3P) at least to give an indication of weak cells?
Also make of your ODD2 dongle ( does it use bluetooth 1.5) also phone model and android Version as I am in the market for a (new?) one, Thanks
^^^^^What does "Battery Health (SOH)" mean?
State of Health
State of health is a highly subjective term that is entirely managed by the on-board battery management system. The state of health is most likely individually like a non-standardized list of sub categories similar to a SMART report generated by hard disk drives in computers. The battery system is clusters of batteries in series (that allows the 1.5v individual cells pair together to achieve the high voltage output of 200+ volts as well as the cell series groups are stacked behind each other to create mass storage (parallel). The batteries need to be carefully managed both during recharge and discharge to make sure individual cells and groups are drained and refilled together and to monitor if battery packs are failing to hold charges and such. If this isn’t monitored and managed by the system an imbalance will occur and you’ll be told the battery is at 100% when in fact it might be 75% and you’ll see a drastic drop in range etc. The system needs to be able to track and report if a particular pack is failing so during maintenance a pack can be swapped that is prematurely failing or otherwise not working as expected. Also obviously it also tracks and monitors overall health and wear so the storage from a “new” state is determined. This entire system would be entirely proprietary and designed and managed by the battery maker and car manufacturer. Basic data can be read and determined by the obd2 system most likely hence all that data being converted into a state of health but their own systems can probably generate the detailed report from the battery system to figure out what, if anything, is wrong.So what does "State of Health" mean?
Thanks. Perhaps the battery's SOH as reported by the BMS is checked during routine maintenance.
But I see zero mention of it in the manual. All the maintenance checks appear to be mechanical (except for the 12V battery check).
Presumably one of the warning lights (Service, Power Down, Blinking Ready) will light up if something goes wrong with the battery, and SOH becomes bad, because of an unbalanced cell or whatever.
Apu, that seems reasonable, but it is unclear to me whether this is the # they would use for warranty evaluation.
Maybe so.
Does a 70% SOH imply that the fully charged vehicle's range is reduced to 70%?
Nonetheless, and whatever SOH actually entails, it would be useful to monitor this # as you suggest.
I had a 2002 Toyota Prius - what people do not realize about hybrids, that they continuously charge the battery to 100% even while driving. Mine lasted for 500,000 miles or 15 years. The car is still on the road with the same battery. Range fluctuates on so many variables. Just be aware where your charging options are.You guys are all awesome .
I'm glad I signed up to the forum to check in with other Kona owners. Like Wildeyed, I'm a routine 'to work and back driver'. I didn't realize the car was customizing the range to my driving habits and was predicting the range after a charge. Ill continue to charge to 100% vs 80% As I though I was harming the battery doing full charges. From what I read the battery management system looks after the battery behind the scene and charging to 100% in L1 or L2 does no harm.
I would read about battery capacity at Battery University[ note figure 6] because it's really helpful. GM's Bolt EV owner's manual actually wants customers to charge to 100% as often as they want. ideally charge to 65-75% ; 25-85% will help with avoiding degradation.You guys are all awesome .
70% to 45% for me seems to work most of the time, on occasion to 80% if I need the range, mostly weekly L2 and DCFC 2 times a monthI’m a bit like KiwiMe I don’t take all that much notice. I’m more concerned about how I should charge my kona. Some say never less than 20% or more than 80% unless going on a long run. Not sure who’s right so since getting the car in February I’ve stuck to the 20-80 formula [emoji636]
Thanks but your reply highlights what I’m saying, what is the best way to maintain the battery. Everyone seems to have a different idea including the Hyundai dealer.70% to 45% for me seems to work most of the time, on occasion to 80% if I need the range, mostly weekly L2 and DCFC 2 times a month
