Bardolph,
If you have a
240 Volt, 40 Amp outlet near your Bolt, you are 2/3 of the way to Level 2 charging. Yes, you can purchase a Level 2 EVSE charger (mine is an Aeronviroment - now owned by Webasto) for $500-600. This is your simplest solution. The Aerovironment / Websco requires a
40 Amp circuit, and charges your Bolt at
32 Amps, in
8 - 9 hours. Whoever said charging at 16 Amps will complete the charge in 8 - 9 hours was incorrect. 32 Amps charges at the rate of
24-25 miles per hour, needing 8 - 9 hours to complete the charge (from a full depleted battery). A 16 Amp circuit will charge your Bolt at
12 miles of charge per hour, and take
18 hours to completely charge your Bolt.
Charging with the 120 Volt
Level 1 plug and charger,
that comes included with your Bolt, will work if you charge every day and never drive too far. It charges at the rate of
5 miles of charge per hour and will charge your Bolt completely in
48 hours.
One of the most
flexible charging set-ups available is to use the Tesla UMC. Any outlet for 240 Volt / 40 Amp receptacle will work. Buy a Tesla
UMC (
Universal
Mobile
Connector) ESVE.
Model 3s require 240 Volts/32 Amps exactly like your Bolt. These are $300 direct from Tesla, but I picked mine up (new) on ebay for
$220. Specify your plug type, or buy a connector to fits between the EVSE and your wall plug from Tesla for $35. They stock 6 to choose from. I have a
NEMA 6-50 plug, but a
NEMA 14-50 also works if that is your plug type. Finally you must purchase a Quick Charge Power (
www.quickchargepower.com)
Jdapter Stub ($240 +20 shipping). The Jdapter Stub connects to your charging port with the Bolt compatible
J1772 plug. The other end attaches to the
Tesla plug of the
Universal
Mobile
Connector. For the ultimate in Level 2 connectivity, buy the
14-50 for emergency stops, or stays at
RV parks.
There should be no installation costs because you have a 240 Volt / 40 Amp circuit with receptacle. Certainly my Aerovironment has a plug-in option.
So, why all this trouble and complexity? Using the
UMC and Jdapter Stub combination you can charge at your 240 Volt/40 Amp plug at home. Using a J1772 port on your Bolt will allow you to charge at many Level 2 EVSE away from home (ChargePoint, Blink, EVgo) -
but not all. Taking your
Jdapter Stub on a trip you can charge (with permission, and included at many hotels) any Tesla
Destination Charger, Tesla HPWC (
High Powered Wall Connector), Tesla
UMC, Tesla
Mobile Connector, or Tesla
Wall Connector.
Recently I drove from Las Vegas to Phoenix, 300 miles, and back in my Bolt. On the way I stayed at the
Best Western Plus A Wayfarers Inn in Kingman, Using the motel's Tesla
Destination Charger, I charged up my Bolt with my
Tesla to J1772 Jdapter Stub overnight. Then on to Phoenix and charging at
Cambria Hotel and Suites, North Scottsdale (Tesla
Destination charger again). I visited with my daughter and granddaughter all day, then with a full charge, retraced my steps.
Hope you are driving electric. I really enjoy our Bolt. Check out the Kona Electric.
