Charging and power outages
  • Thread starter Thread starter KonaTom
  • Replies Replies 16
  • Views Views 3K
KonaTom
Does anyone know what happens when the power goes out during a trickle charge (or even a level 2 charge)? Does the charging resume when power is restored?
To my knowledge the EVSE just resets and restarts but it may depend on which brand you have. I have a JuiceBox Pro and it will just reset and continue where it left off.
I would think you're right. The level 1 cable doesn't even have any buttons (other than Amp select). You plug it in and it charges. So a power loss is basically no different than unplugging and plugging back in.
But they say to plug in the household current first when trickle charging, then the car. If the power fails, both will be plugged in same time when it comes back on, and I wonder if that will be an issue. I had a short power outage last night, but I had disconnected the charger before I went to bed, but starting wondering what would have happened if it was plugged in overnight. Hopefully it will just start charging again, or it could be an issue for some people.
I believe the Evse has to do a 'handshake' with the car before it sends power so the unit will have to wake up first before it will allow power to flow. The Evse has signal wires in the cord section that connects to the car. When you plug it in, the car and the Evse will make the handshake, the Evse will tell the car how much power it can supply (16amp, 32amp, 40amp etc), the car will tell how much it wants (Kona maxes at 30ish I believe), then the Evse will begin supplying power until the car says stop.
I only trickle charge, so hopefully it will work okay. Waiting for the govt. to restart the home charging grant to get an evse. I guess one thing I could try would be to plug it into the car first, then the 110 plug and see if it works, or if I can figure out what circuit breaker to pull and test it that way.
It should be the same, the trickle charger still has to do the handshake routine. I believe that is part of the J1772 standard (the cord end that you plug into the car is generally called a J1772 connector because it is only used with the J1772 charging standard).
You can test it by turning off the breaker that your trickle charger is plugged into while the car is charging, and then turning it back on in a bit and seeing what happens. The car should just treat it as a disconnected cord and do the handshake process over again.
going to try that today!
Exactly.
Or your car blows up, so don't stand right next to it! [emoji6][emoji23]
